Question about British Telecom Lands Phones
The handest no1 is showing on the display no base link check base
How do i enter code on model mod8691mb1
Turn radio on, 1 will appear in the display. Via the 6 preset buttons enter the 6 digit security code. As each number is entered the number will be displayed in the lcd. If the correct number was entered the unit will operate after a few seconds. You get 3 goes then you have to wait an hour to try again.
For the cd- A small No1 & a large No1 will appear on the screen. the small 1 shows the No of code entry attempts
, the large 1 is the first No of the code. Use the track up/down button to change the 1 to the first No of the code. press the play button to store the No. The entered No will move to the left & the No 1 will appear next to it, repeat for all 4 numbers. If the correct No was entered the lcd will go blank & a cd can be inserted.
Hope this gets u going cheers
Apr 03, 2017 | Car Audio & Video
I have uniden cordless phone model dxa15588-2, how do I register handset on base?
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
Nov 17, 2010 | Uniden Cordless Phone
Will uniden 6.0 handest work with an existing 5.8 system? I have an 5.8 system for about 4 years I think the handset cordless is not holding a charge so I would like to purchase additional cordless sets...
Your 5.8 system utilizes analog transmissions at 5.8 GHz between the base and handset. The DECT is digital at 1.9 GHz. Sorry, but the two systems are totally incompatible.
BillB
Jan 29, 2010 | Uniden Lands Phones
Registering a new handset with the base
I want to sigmatel t33i phone lock code\r\nplz
Sep 08, 2009 | Uniden Cordless Phone
Can´t register handset . Panasonic KX-TG2620BX
I forgot dial lock, piease help me to open dial lock
Aug 31, 2009 | Panasonic KX-TG2620 2.4 GHz Cordless Phone
Triple dcoe40 on tr6. Vacuum on no1 cyl is poor at
What is the condition and adjustment of the "o" rings and the spring compression washers? sounds like an air leak . one thought where does the crank breather connect to?
Aug 15, 2009 | 2006 Triumph Tr 7
Phone will not Download anything from the web
Hi fuckidono, from the sounds of it you have the wrong settings installed for ur gprs, or maybe you have multiple gprs settigns installed on your handest, the best thing i can suggest is that you completely remove all gprs settings from your handest and have your network provider resend the gprs and multi media messenger settings to your phone, this should work, hope this answers ur question, goodluck from ben.
Mar 27, 2009 | Motorola Mobility RAZR V3
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Lands Phones Logo
49 people viewed this question
Top British Telecom Lands Phones Experts
David Burbee
David Burbee
Andrew Taylor
Andrew Taylor
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
