Question about LG Washing Machines
FRONT PANEL IS DEAD RELAY TICKING AND RED LED FLASHING
I HAVE A LG WM12235FB FONT LOADING WASHING MACHINE, THERE IS NO LIGHTS OR LED DISPLAY WORKING ALTHOUGH IT DOES HAVE 240V IN. THERE IS A RELAY TICKING ON THE BACK OF THE CONTROL PANEL AND A RED LED FLASHING IN TIME WITH THE RELAY. aNY IDEAS
  • 1 more comment
  • davebret7 May 19, 2009
    This would give you some life on the control panel I would have thought ! this is not the reason behind the problem
    There is nothing in the washer it is empty, the door can be opened and the drum can be moved round
    Any further help on the red flashing LED and relay with this problem as the last response i could have got myself
  • 749 Answers
You will have to get the led display replaced.
Posted on May 19, 2009
  • 3,230 Answers
Many front loading machines have to be fully off, as in the dial is on off and pulled out (or pushed in) whichever is the direction for "off." Otherwise there is a secondary latch on the door that stays shut to prevent accidentally opening it during a wash cycle.
check that first.
post further comment for more help.
Thanks
  • Mukesh Kumar May 19, 2009
    You need to chack for something, means it seems there must be someting stucks in that washer..
    Check that...
    Thanks
    Well, seems that there must be some problem in the control board of your washer..
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Lg front loader washing machine has no power
You will need to unplug the washer, remove the 4 screws from the white plastic pieces on the rear of the machine main top, remove the top by sliding to the rear, locate your main computer board in the top left, plug the washer into the wall, check for a small red LED light glowing on the board. You may have to unplug the washer again and remove the cover in front of the computer board to be able to see the light. If there is no red light your main control board is out, but this could have been caused by another failure such as a faulty stator, or rotor on the motor. Sometimes the connecting wiring from the front control panel to the main rear board will become loose and suffer damage against the moving tub. Best to have a qualified repair company check things out. Pleazer Appliance...
Apr 14, 2014 | LG WM-2277HW Front Load Washer
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Help!
sound like the display board might be dead
Feb 28, 2010 | Washing Machines
When I start my LG WM2101HW washer, the spin light
sounds like a clitch under warrenty would call them out so you dont void warwrnty
Dec 06, 2009 | Washing Machines
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Once I turn on the machine, I hear the "on" beeps but no lights on the controls and no display either.
if yours has the control board mounted in back of machine, is there a red led lit on it? this indicates operation of main board. if lit then replace user interface.
Dec 03, 2008 | LG WM-2277HW Front Load Washer
INDESIT 1000 DOES NOT START
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Nov 07, 2007 | Washing Machines
Washing Machines Logo
136 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
