Function Key has stopped working.
The Function Key has stopped working or has become locked, on my Fujitsu Siemens Amilo Li2735. How can I get it started again. I need it specifically to press in conjunction with Key F1 in order to be able to open my broadband connection to the internet. My laptop is still in guarantee.
Laptop hinge wont move
I would loosen or unscrew the 8? screws that hold the display on, this will loosen it off without everything coming apart, then tilt the screen down, lift the from the bottom of the screen, pry without breaking, take that panel off and see if you can replace or find the part that came out, it maybe screws or another piece. You can probably put it back together if it fell out, then just put the screen plate back on.
Aug 23, 2013 | Fujitsu Siemens Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
I cant find my wireless switch on my fujitsu siemens amilo pro laptop
Try hitting fn+f1 at the same fn= function key hope this helps you
Jan 05, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
I can't get wireless to work on my fujitsu siemans amilo
Hello.It seems with the driver from your wireless card. Try reinstalling it.
Mar 15, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 13, 2009 | Fujitsu AMILO PC Laptops
TURN ON WIRELESS ON LAPTOP
check your wireless working fine
go to my network places.then view your wireless network if any network u see then connect.
also if your router is setup in security mode u have to add your wireless mac addresses in allow list in your router,
type in run "ipconfig /all" then u see mac adreses.
Nov 26, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Disable locks
There should be a function key to toggle the number lock off.
Some laptops it is the <SHIFT><NUMLCK> and some <FN><F1>
see if you have a numlck key or if a F (Function) key has a picture of a Lock, also make sure in the BIOS setup utility Numbers Lock on boot is not selected.
May 25, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Laptop Hot Key not working...
Unless you deleted it. You can go to control panel, keyboard and reprogram the key. Or if there is a special keyboard program, you can use that.
Dec 28, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Wireless capabilities
hit the Function key (usually "Fn") then F2 should work. Also on most Fujisu's the wifi button is some where around the top left might want to try that also with or without Fn.
let me know if everything works out, also please take the time to rate me!
-Daniel.
Nov 19, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
