Question about Spirit XT285 Treadmill
I need to level - Spirit XT285 Treadmill
Gl1200 float level
My first guess would be the float bowl for the carburetor. The fuel level needs to be maintained at a specific height in the bowl. There's a float inside that activates a valve which allows fuel to fill the bowl - once the correct level is reached, the valve closes. On my old Virago there were simply two tangs inside as I recall that needed to be bent manually to make the adjustment. To check the level you would attach a piece of clear tubing to the drain port on the bottom of the bowl.....when the drain was opened the fuel would fill the tube to the same level as is in the bowl. You would need to find the correct spec for that level and adjust if necessary.
Aug 04, 2012 | 1986 Honda GL 1200 Aspencade Gold Wing
Hello, how to make epson T13 without the chip, can let me know? thanks,
EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME . INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF. INK LEVEL LEVEL ALWAYS SHOW 100 % NO WASTE INK PAD COUNTER MORE NO NEED TO WORRY WHILE PRINTING MORE PRINT JOBS
Jun 21, 2011 | Computers & Internet
Where is the transmission dipstick in my manual 1.3 liter 1993 suzuki swift located and where do i fill it up?
LEVEL CHECK With Oil Level Gauge Fig. 1: Manual transaxle oil level check - with level gauge 84241046.gif
  1. Drive the vehicle to bring the transmission up to operating temperature.
  2. With the engine stopped, remove the oil level gauge front the side case of the transaxle.
  3. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  4. Wipe off oil level gauge with clean cloth.
  5. Fit the oil level gauge to the transaxle side case so that the threads rest on top of the case.
  6. Remove the gauge and check oil level. The level should be between FULL and LOW level line.
  7. If the level is below LOW mark, add oil until the proper level is reached.
With Oil Level/Filler Plug
  2. Raise and support the vehicle safely.
  3. Remove the transaxle oil level/filler plug.
  4. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  5. Transaxle oil level should be even with the bottom of the plug hole. If oil level is low, adjust oil level accordingly.
  6. Install transaxle oil level/filler plug and tighten to 40 ft. lbs. (54 Nm).
  7. Lower the vehicle.
Oct 17, 2010 | 1993 Suzuki Swift
Oil level in the forks of a 94 cr250r
Ok, here it is right out of the stock 94 CR250 manual (dry):
Standard (stock) spring (.38 kg/mm)(1coil at top of spring) - SS-7M or equivalent oil.
.... Standard oil level is 118mm (559cc)
....Maximum oil level 93mm (584cc)
....Minimum oil level 136mm (541cc)
Optional light spring (.36 kg/mm)(3coils at top of spring)
....Standard oil level is 116mm (561cc)
....Maximum oil level is 92mm (585cc)
....Minimum oil level is 134mm (543cc)
Optional Heavy spring (.40 kg/mm)(2 coils at top of spring)
....Standard oil level is 125mm (552cc)
....Maximum oil level is 101mm (576cc)
....Minimum oil level is 143mm (534cc)
good luck
Jan 17, 2010 | Honda CR 250 R Motorcycles
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
LEVELING FREEZER
It is important to level the freezer. To do so you will need level, generally a 12 inch or 24 inch available at any hardware store.
The legs generally unscrew from under the unit to help in leveling. sometimes, depending upon how unlevel the floor is you may need to use blocks of lumber to level it up.
Jun 20, 2009 | Freezers
Need to level my kenmore 25 cu side by side-don't have a manual
take of your front kickplate you see the leveling screws on either side
Mar 15, 2009 | Refrigerators
Samsung F250
The code is: *#0206*8378#
Then go in: H/W Test > Audio Settings > MP3 spk
change 'ear gain' to 14.
Then, enter 'Rx vol.'....
I made this changes:
Level 1: 150
Level 2: 180
Level 3: 210
Level 4: 260
Level 5: 300
Level 6: 370
Level 7: 460
Level 8: 550
Level 9: 640
Level 10: 700
Level 11: 800
Level 12: 1000
Level 13: 1350
Level 14: 1400
I made this changes and the sound of mine became very loud now...
You can do your own changes, but don't abuse.
\o/
May 29, 2008 | Lands Phones
I need help to level my kitchenaid fridge, and the owner manaul does not show this.
leveling refrigs, can be abit tricky, depending on level of floor especially, for the most part only the front 2 legs/wheels are going to be adjustable, the rears if need be will have to be chocked with wood shims . as a repairman for nearly 20years, i rarely "level" refrigs, , for the reason of who knows if the cabinets are level, or how level the floor is, i in turn make the refrig appear level and make sure its stable when the doors are opened and closed. not essential for level (shloud be close butno need to be perfect, id much rather a refrig tht looks good and doenst shake when door is closed, rathe then tryin to get it perfectly level and then seeing a 2 inch gap at top of cabint and flush against the bottom.
Apr 03, 2008 | Refrigerators
Spirit XT285 Treadmill Logo
12 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Mister G
Mister G
Level 1 Expert
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
