Question about Proscan Televison & Video
Proscan led tv will show green light but no picture and no sound then cannot turn off unless i unplug
Proscan 24" led will not turn on just green light comes on but no picture and no sound. then will not turn off needs to be unplugged
SOURCE: No picture - power indicator shows red
It will have to go into the shop! Our LG Plasma did the same thing twice now.
Posted on Apr 01, 2008
  • 1894 Answers
SOURCE: 42 inch Akai plasma - no pix no sound
i think your power board has some serious problem
Posted on May 21, 2008
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
dsacco86
  • 1077 Answers
SOURCE: TV won't come on - get a blinking red light instead
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you the flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 01, 2009
  • 44 Answers
SOURCE: NO Picture or Sound on my FLM 26-32
Either one of two problems, the main power supply has an issue or has gone bad. 'Not supplying the correct voltages to your processing/controlling board' or that you are having problems with your processing/controlling board. My guess is the main power supply board.
A Good TV Service Shop would give you an idea of what the cost of repair should be. Call around.
Blessing,
A/V Media Tech Guy
Posted on Nov 24, 2009
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
Just do a hard reset to this set and check. To make it a hard reset, unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If this do not help you, the main board to your TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 01, 2014 | Proscan Televison & Video
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
My lcd tv powers screen lights up but no picture
Try turning off and unplugging the TV for 24 hours. It could also be a power supply issue. In that case you should get it fixed or replaced.
Aug 02, 2011 | Proscan 32LA25Q 32 in. LCD TV
LED goes from red to green then back to red, when
led goes from red to green and back to red when turning tv on
Dec 27, 2009 | Proscan 19LA25Q 19 in. LCD Television
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Picture and sound problem at 21" sony waga color tv
This is due to problem in deflection area and power supply section malfunction. Make one general service by technical person immediately to avoid major transformer failure problem. Since this is initial stage, the cost of repair is probably less.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
19 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
