Question about Seiko SNAE97P1 SNAE97P SNAE97 Sportura 100m Pilot Mens Watch
Cant set alarm - Seiko SNAE97P1 SNAE97P SNAE97 Sportura 100m Pilot Mens Watch
I cant set the arm time
[PDF]The Apple Watch User Guide (PDF)
https://manuals.info.apple.com/.../apple_watch_user_guide.pd...
Apple Inc.If you have difficulty seeing the Apple Watch or iPhone screen to set it up, .... Note: If you disable your passcode, you can't use Apple Pay on Apple Watch. ..... Alarm • Timer • Stopwatch • Battery charge • World Clock • Your monogram (displays ...
[PDF]Cal. 7T62 - Seiko
www.seikowatches.com/support/ib/pdf/SEIKO_7T62.pdf
SeikoYou are now the proud owner of a SEIKO Analogue Quartz Watch Cal. .... into consideration the time required to set the ALARM hands and to adjust the .... The single-time alarm cannot be set for a time more than 12 hours ahead of the current ...
How to Set an Alarm on the Apple Watch - YouTube
Dec 26, 2015 | Watches
I cant stop the alarm from going off every 5 minutes, please assist
The user instructions that the maker publishes are generic only and not model specific, so try go to http://www.genevawatchgroup.com/pdf/kc_reaction/KennethColeReaction_US.pdf and scroll down to the alarm setting section.
With any luck, your watch will be covered by these instructions.
Jan 21, 2011 | Kenneth Cole 1213 Wrist Watch
Have casio watch quartz alarm 100 meter and cant set day month
If you don't have the manual, You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Feb 14, 2010 | Watches
I just cant set my alarm,Help me
Go to the web site "www.pulsarwatches-europe.com/index.asp" .
From the tabs across the top select "instructions"
Enter the details required from the information on the back of the watch.
Download the instrucitons.
Jan 07, 2010 | Pulsar 100 Meter Alarm Chronograph PF3277
I have a Casio DB360 digital watch - How do I turn
Read the manual... http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2515.pdf
Jun 27, 2009 | Casio Watches
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
I cant set the digital time in casio illuminator
1) Home City
2) Home city and Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to return to timekeeping mode.
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Apr 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Mossimo alarm
While in (digital) Clock mode (NOT in alarm setting mode!!!), push the bottom-right button and then the top-right, to toggle alarm on & off.
Jan 29, 2009 | Bulova Men's Watch
How to set the alarm on a seiko presage chonograph?
Try Googling (Seiko)(SUY055)(manual) without parens for instructions.
Dec 15, 2017 | Seiko Presage SUY055 Wrist Watch
Seiko SNAE97P1 SNAE97P SNAE97 Sportura 100m Pilot Mens Watch Logo
18 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
