Question about JET Performance 2003 GMC Sierra 2500 HD Mass Air Flow Sensor
Code p0040 lose power
What are the probable causes of DTC P0040?
On most models code 40 means the harness connectors for the two O2 sensors are reversed.
Apr 08, 2016 | 1998 Pontiac Grand Am
What does error code P0040 mean on a 2004 Chrysler Sebring touring
O2 sensors connections for the front sensors are swapped, open (cut) or shorted out. The PCM may be bad if the sensors and wiring are ok.
If you recently worked on the sensors check your wiring. If not, You probably have a bad O2 sensor or the wiring is at fault.
Sep 15, 2015 | 2004 Chrysler Sebring
Battery Light
Po040 and 041 are oxygen sensor codes for reversed connections . intermittent charging open circuit in alternator brushes .
Mar 21, 2014 | 1998 Chrysler Town & Country
Code 41
code p0040 refers to oxygen sensor signals swapped , bank 1 sensor 1 / bank 2 oxygen sensor 1===causes --wiring problems . Check that the wiring connections on the ECM or swapped on the sensors or wrong sensors in the system. One will be HO2S and the other is a O2S
What will set a trouble code P040 ?
If the code is P0040, the common problem is the O2 sensor wires have been switched between the sensors on bank one and bank two.
Aug 29, 2013 | 2000 Buick LeSabre
1999 Jeep Grand Cherokee Laredo 8Cyl4.7L When when driving over 50 miles per hour will lose all power whats wrong?
When you say it loses power, do you mean electrical power or engine power ?
You would need to look at the fuse boxes for a loss of electrical power, and use a scanner or code reader to check the computer for trouble codes for a loss of engine power.
Sep 18, 2012 | 1999 Jeep Grand Cherokee
2001 saturn code po500 , b0045, b0040
p0040 is Oxygen sensor signals swapped Bank 1 sensor 1/Bank 2 sensor 1.
p0045 is Turbo/ Supercharger Boost control solenoid circuit open.
p0500 is vehicle speed sensor A.
Sep 25, 2011 | 1999 Saturn SL
I have a code P040 check engin. What correspond this code Thanks!
Improve the Fixya.com experience for everyone by voting!
Unfortunately, you did not provide a year and a model and I cannot give you a precise response
Translation:
P0040 Upstream Oxygen Sensors (HO2S) Swapped From Bank To Bank
Your heated oxygen sensor is not properly transmitting data to your PCM (onboard computer), You'll need a code scanner that you can borrow for free from AutoZone.
All the best,
Ben
Jul 09, 2011 | Pontiac Sunfire Cars & Trucks
On my 1998 crysler sebring I am getting OBD II codes of 40 and 41,Transmission & engine module,any suggestions where to start? Thanks.
code 40-
Possible causes - 1/1 And 2/1 O2 sensors harness circuit shorted
- 1/1 And 2/1 O2 sensors harness circuit connectors (wrong connection)
- Faulty Powertrain Control Module (PCM) P0040 CHRYSLER Description At ignition on the Powertrain Control Module (PCM) checks the voltage on the ground side of the O2 sensor harness connector. If voltage is higher than two volts the P0040 code will set. code 41- Possible causes - 1/2 And 2/2 O2 sensors harness circuit shorted
- 1/2 And 2/2 O2 sensors harness circuit connectors (wrong connection)
- Faulty Powertrain Control Module (PCM) P0041 CHRYSLER Description At ignition on the Powertrain Control Module (PCM) checks the voltage on the ground side of the O2 sensor harness connector. If voltage is higher than two volts the P0041 code will set.
Dec 01, 2010 | 1998 Chrysler Sebring
JET Performance 2003 GMC Sierra 2500 HD Mass Air Flow Sensor Logo
Top JET Performance Computers & Internet Experts
David Payne
David Payne
Are you a JET Performance Computer and Internet Expert? Answer questions, earn points and help others
