Question about LG 37LH3000 37" HDTV LCD TV
Horizontal white lines when set becomes warm
Been away for a fortnight returned home switched tv on after approx ten mins screen filled with horizontal white lines, turn telly off for 15mins turn back on same fault?
  • 12 Answers
SOURCE: solid white horizontal line
Have a look at my 'I broke the glass post'
Posted on Jun 06, 2008
nikonian2
  • 154 Answers
SOURCE: lg tv type PT-48A80T
a defective product , bring it back to the store and swap it for a good one
Posted on Nov 30, 2008
  • 39 Answers
SOURCE: Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Posted on Feb 20, 2009
taiwandennis
  • 6 Answers
SOURCE: My brand new LG 32LH20 Gets Horizontal white lines
YOUR TV MAY HAVE BEEN DROPED ILL TAKE IT BACK
Posted on Sep 23, 2009
Testimonial: "thanks"
  • 1779 Answers
SOURCE: my LG plasma screen keeps freezing up after about
Replace the digital logic board, or, my recommendation is to take it in for service to have it properly evaluated.
Posted on Feb 19, 2010
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
White horizontal lines covering picture on Toshiba 51HC85
The set uses a Hyper board inside that processes all signals, it is well known for this issue, board no longer available=reason is quite simple : about a dozen tiny surface mounted filter caps on that board with age dry out, at first it will work after warms up as poor caps regain some capacitance and seem to be ok.
Buy a new set, you can send that board out and have it repaired/rebuilt but the last one I saw which was under extended warranty cost about 200 just for the board rebuild.
In the last 4 years Here on Fixya I have encountered only 2 people who were able with instructions had the skill to remove the board and replace those caps, both were top notch computer repair techs.
Dec 09, 2012 | Televison & Video
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Aug 14, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Top section of the picture gets reversed and compressed
Dear simon, Seems like a simple problem. In all likelihood, one of the Electrolytic Capacitors in the vertical Output stages has failed.It could also be a cold / dry solder, as symptoms seem to disappear when you tap the set. But, do not try anything thing at home. A proffessional Techie should fix it up in 15-20 mins. Definitely worth the spend.
Aug 02, 2006 | JVC AV-27230 27" TV
LG 37LH3000 37" HDTV LCD TV Logo
Computer Repairing
Computer Repairing
