Question about Canon PowerShot S120 12.1-Megapixel Digital Camera
Where do I get authentication code? I get to click on cloud icon but no code pops up
Authentication code does not pop up when I select the cloud icon. Where do I go to get the authentication code required for the
2 Suggested Answers
Charlesmgray
  • 24 Answers
SOURCE: Our canon C3220 is not printing from one of the computers in the office. It is putting all print jobs on hold due to authentication required
Auth Required sounds odd. The only thing i could think would cause this is if the copier itself has Department Managment enabled. This is used to limit printing by quanity and sometimes restricting color prints. IF everyone else in the office is required to enter a code to print and this one does not then you need to enable department ID via the driver settings. Right Click your print driver and go to properties and select "Device Settings" from the tabs on the top of the window. Under this menu there should be a box that says Department ID select that and try it out. Another way is to "aquire" the copiers device status a button labeled somewhat to this effect should also be in that same window.3_15_2012_4_29_14_am.jpg
Posted on Mar 15, 2012
I cannot access my emails in my outlook account on my Toshiba CB50 Laptop it keeps saying theres a problem with my account why is this?
Solution: Make sure that your computer is connected to the Internet or your network. Use a Web browser to see whether you can access Internet sites. If you are on a local network, see whether you can access intranet sites. For information about checking the status of your network connections, see Mac OS Help. Solution: Verify that Outlook is online. On the Outlook menu, make sure that Work Offline is not checked. Cause: Some POP and IMAP e-mail accounts use an outgoing mail (SMTP) server that requires authentication. Solution: Turn on SMTP authentication for the POP or IMAP account. Some e-mail services, including MobileMe mail accounts, require authentication for their SMTP server. If you verify that all your account settings are correct, but you still can't send messages, try turning on SMTP authentication. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Under Outgoing server, click More Options. On the Authentication pop-up menu, select the authentication type, and then enter your credentials as necessary. Cause: Your ISP or network has a firewall that blocks connections to your e-mail service's outgoing mail (SMTP) server. Solution: See if your ISP or network administrator can provide an alternative SMTP server to use for your POP or IMAP account. If you have the address of an alternative SMTP server, enter it in your account settings. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. In the Outgoing server box, type the server name or address. NOTE: If you use a laptop computer in multiple locations, such as at home and at work, the SMTP server that you use in one location may not work in other locations. Each Internet connection that you use may have a firewall with its own restrictions. Cause: Your credentials or account settings are incorrect. Solution: Verify that your account user name, password, and other settings are correct in Account preferences. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Make sure that you have entered the correct e-mail address, user name, and password. If your account still does not work properly, check with your e-mail service provider for details about how to configure your account in a mail application. Your account may require that you use special settings such as Secure Sockets Layer (SSL) to connect, or that you override the default port. Cause: Your network requires a proxy server to connect with the mail server. Solution: Specify a mail proxy server in your computer's System Preferences. If you use a network to connect to the Internet, you might have to specify a mail proxy server. Ask your network administrator for the correct settings for your mail proxy server. For instructions about how to enter these settings, see Mac OS Help. Cause: Your e-mail server is unavailable. Solution: Make sure that the mail server is online. If you successfully connected to the account before, the mail server might be offline. Contact your e-mail provider or network administrator to see whether the mail server is available.
Mar 25, 2016 | Toshiba Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Hotmail pop and smp codes
  • POP server: pop3.live.com
  • POP server port: 995
  • POP SSL required? Yes
  • User name: Your Windows Live ID, for example yourname@hotmail.com
  • Password: The password you usually use to sign in to Hotmail or Windows Live
  • SMTP server: smtp.live.com
  • SMTP server port: 587
  • SMTP Authentication required? Yes (same as POP3 username and password)
  • SMTP TLS required? Yes
Aug 10, 2015 | Google Computers & Internet
Can I configure microsoft outlook 2007 to work with my yahoo e-mail if i'm connection through clearwire at home and I'm not on a network
If you are not connected to the internet, you can only work offline, and for example, if you write an email it will not send until you do connect to the internet.
You can configure Outlook 2007 to work with Yahoo.
If you want to "POP" your Yahoo! Mail into your Outlook 2007 application, here's how:
  1. From the Tools menu, select "Account Settings." If you do not see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the Email tab, click New.
  3. Check the box next to the first option, "Microsoft Exchange, POP3, IMAP, or HTTP" and click Next.
  4. In the Your Name box, type your name as you'd like it to appear when you send a message.
  5. In the Email Address box, enter your Yahoo! Mail address (for example, "user@yahoo.com").
  6. Check the box for "Manually configure server settings or additional server types" and click Next.
  7. Check the box next to the first option "Internet E-mail" and click Next.
  8. In the Server Information area, under "Account Type" select POP 3 from the pull-down menu.
  9. In the Incoming mail server field, enter: pop.mail.yahoo.com.sg
  10. In the Outgoing mail server (SMTP) field, enter: smtp.mail.yahoo.com.sg
  11. In the Login Information area, in the User Name field, enter your Yahoo! ID (your email address without the "@yahoo.com").
  12. In the Password box, enter your Yahoo! Mail password.
  13. Check "Remember Password" if you don't want Outlook to prompt you for your password each time you check your mail. Handy!
  14. Do not check the box labeled "Log on using Secure Password Authentication (SPA)."
  15. Click on the More Settings button.
  16. Click on the Outgoing Server tab and check the box next to "My outgoing server (SMTP) requires authentication."
  17. Click on the Advanced tab.
  18. Under "Incoming Server (POP3)", check the box next to "This server requires an encrypted connection (SSL)". The port number in the "Incoming Server (POP3)" field should automatically change from 110 to 995. If it doesn't, make sure the port number is set to 995.
  19. Under "Outgoing Server (SMTP)", check the box next to "This server requires an encrypted connection (SSL)". Enter port number "465" in the "Outgoing Server (SMTP)" field.
  20. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, don't check the box.
  21. Click the OK button.
  22. Click the Next button on the Email Account Wizard, then click Finished.
  23. Would you like your Yahoo! Mail inbox to be your primary inbox in Outlook 7? If so, click the Tools menu and select "Account Settings." If you don't see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  24. From the list, select the pop.yahoo account you've just added and click the Set as Default button.
  25. Click the Close button. You're done!
Troubleshooting instructions
If you followed the above configuration steps, you should be all set. However, if you cannot send or receive mail with your email client, try the following tips.
The Yahoo! Mail SMTP server requires authentication. Make sure you have enabled SMTP authentication. To turn this setting on, follow these steps:
  1. From the Tools menu, choose "Account Settings."
  2. Select the "E-mail" tab.
  3. Select your Yahoo! Mail account and click Change.
  4. Click on the "Outgoing Server" tab.
  5. Check the box next to "My Server Requires Authentication."
  6. Please make sure that "Log on using" is not checked.
  7. Click OK.
To control deletion of messages from the Yahoo! Mail server:
  2. Click on the "Email" tab.
  4. Click on the "Advanced" tab.
  5. Check "Leave a copy of messages on server" if you want to save your Yahoo! Mail messages on the Yahoo! Mail server as well as on your local computer. Please note that setting your email client to remove messages from the server will cause your messages to be deleted from the server. Once the messages are deleted, we are unable to retrieve them.
  6. Click OK.
  7. Close Microsoft Outlook and restart.
We strongly recommend that you enable SSL for both POP and SMTP, as detailed in the above instructions. This will ensure that your Yahoo! ID, password and email messages are transmitted securely between your mail client and the Yahoo! servers. However, if you choose to not use SSL for SMTP, your email client will likely default the SMTP port to 25. If your ISP blocks port 25 or if you're unable to send email, then you will need to use port 587 when sending via Yahoo!'s SMTP server. To make this change, please follow the directions below:
  1. From the "Tools" menu, select "Account Settings"
  2. Select your Yahoo! POP account and click on Change.
  3. Click on the "Advanced" tab.
  4. Click OK and Close.
May 05, 2011 | Microsoft Office Computers & Internet
Im trying to set up the hotmail on the samsung 5560
TO SETUP MAIL CLIENT TO ACCESS WINDOW LIVE HOTMAIL ACCOUNT,USE THE FOLLOWING HOTMAIL POP3AND SMTP CONFIGURATION SETTING.
INCOMING SERVER(POP3): pop3.live.com
INCOMING SERVER POP PORT:995
INCOMING SERVER POP SSL ENCRYPTION:YES(ON OR REQUIRED)
OUTGOING SERVER:smtp.live.com
OUTGOING SERVER PORT:25
OUTGOING SERVER AUTHENTICATION:YES(USE POP USERNAME AND PASSWORD OR HOTMAIL CREDENTIONAL)
OUTGOING SERVER TLS OR SSL ENCRYPTED CONNECTION:YES(ON OR REQUIRED)
TIPS: OUTGOING SERVER OF HOTMAIL ALSO SUPPORTS PORT 587,USEFUL FOR PEOPLE WHO ENCOUNTERS ERROR FOR SMTP DUE TO ISP BLOCKAGE OR ANY OTHER REASON
USERNAME: YOUR HOTMAIL ID
PASSWORD: YOUR PASSWORD FOR YOUR ACCOUNT
NOTE: LOG ON USING SECURE PASSWORD AUTHENTICATION (SPA) CHECK BOX IN OUTLOOK,OUTLOOK EXPRESS OR WINDOW LIVE MAIL SHOULD NOT BE SELECTED.
THANKS FOR USING FIXYA.
Mar 04, 2011 | Cell Phones
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Feb 24, 2011 | Xerox WorkCentre M118 Black and White...
When trying to access my wireless network it tells me that it cant locate a certificate to log on to my wireless connection. What does that mean? I have two other children who received these netbooks and...
If u are using Win XP, try the folowing steps.
First, click on the wireless icon in your taskbar and under Related Tasks, choose Change advanced settings.
Click on the Wireless Networks tab and select your network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box.
Once unchecked that box and try to reconnect to the wireless network.
If you are using Win 7 Starter, Try teh following steps.
Click on Start and go to Control panel>Network & Internet>Network & Sharing Center.
On the left side u will find Manage wireless networks. Click on it.
Now select your network in the list. Click on Properties.
Dec 25, 2010 | Acer Aspire One PC Notebook
How to install Microsoft outlook express 2010
Set up your email with Outlook Express
Open Outlook Express.
- Click Tools and select Accounts.
- Click the Mail tab and click Add, selecting Mail.
- Enter your name as you want it displayed.
- Enter your email address.
- Select the type of email server, POP or IMAP.
- Enter the Incoming (POP) server.
- Enter the Outgoing (SMTP) server and click Next.
- Enter the account name that's needed to login to the server.
- Enter the password and check Remember Password.
- If your server requires authentication check the box
- Click Next and Click Finish
Jun 02, 2010 | Computers & Internet
Can receive email but can not send get 530 access denied
Yahoo does not allow to POP emails or configure account in outlook with free email address. After you upgraded to Yahoo Plus follow the steps below
Open your Incredimail page upper above on the menu bar click the down arrow send/receive > Select your yahoo account if necessary click inbox
or
1.From the Tools menu, choose "Accounts."
2.Click on the email account you wish to modify and click the
Properties button.
3.Click the "Servers" tab.
4.Under Outgoing Mail Server, check the box next to "My Server Requires Authentication."
5.Click the Settings button.
6.Ensure that Use same settings as my incoming mail server is selected.
7.Click OK to close the dialog box.
8.Click OK, then Close on the Mail Accounts window.
Enable SMTP server authentication for these email clients:
Hope this helps, let me know if I can help you with anything else.
JimmyC
Oct 08, 2009 | Yahoo Mail
Is it possible to connect MS Outlook to yahoo.com?
yahoo's UK page has instructions on this and here they are: id rather paste theirs than type my own...
  1. From the Tools menu, choose "Accounts."
  2. Select the "Mail" tab.
  3. Click the "Add" button.
  4. From the Add menu, click "Mail."
  5. In the text box labelled Display Name, type your name and click "Next."
  6. In the Email Address box, type your Yahoo! Mail address (be sure to include "@yahoo.com") and click "Next."
  7. Under "My incoming mail server is a…" select "POP3."
  8. Type "pop.mail.yahoo.co.uk" in the Incoming Mail (POP3, IMAP, or HTTP) Server box.
  9. Type "smtp.mail.yahoo.co.uk" in the Outgoing Mail (SMTP) Server box.
  10. Click "Next."
  11. In the Account Name box, type your Yahoo! Mail ID (your email address without the "@yahoo.com").
  12. In the Password box, type your Yahoo! Mail password.
  13. If you want Outlook Express to remember your password, check the "Remember password" box.
  14. Do not check the boxes labelled "Log on using Secure…"
  15. Click "Next."
  16. Click "Finish."
Important: The Yahoo! Mail SMTP server now requires authentication. To turn this setting on:
  3. Double-click the account labelled "pop.mail.yahoo.co.uk."
  4. Select the "Servers" tab.
  6. Click "OK."
  4. Select the "Advanced" tab.
  5. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook Express, don't check the box.
If you're unable to send email, try using port 587 when sending via Yahoo!'s SMTP server. Here's how to make this change:
  1. From the "Tools" menu, select "Accounts."
  2. Select your Yahoo! POP account and click the "Properties" button.
  3. Click the "Advanced" tab.
  4. Next to "Outgoing server (SMTP"), change port 25 to 587.
  5. Click "Apply." Then click "OK" and "Close."
Jan 12, 2009 | Computers & Internet
Canon PowerShot S120 12.1-Megapixel Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
