Question about HP LaserJet 2700n Printer
59 co error on hp 2700 - HP LaserJet 2700n Printer
SOURCE: error co 59
i have printer 5550 error code 59.0 coming so i need hp sevice help
Posted on Jun 14, 2009
seeker5211
  • 1089 Answers
SOURCE: HP color laser jet printer is displaying error
The "developing disengaging motor" has problems. You need a technician. Try running the component test from the control panel. Select the disengaging motor and test it. Maybe it'll start working after the test!
Posted on Jun 05, 2010
mishrajk21
  • 202 Answers
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
Posted on Aug 10, 2010
puertobori
  • 7733 Answers
SOURCE: hp color laserjet 3600 bao
go to --LINK.
Posted on Oct 23, 2010
seeker5211
  • 1089 Answers
SOURCE: How do I fix the chronic error message 59.CO on HP
Developer Motor error.
Power off for 30 seconds. Power on, if error persists get the developer motor replaced.
If the problem still doesn't go away replace the DC Controller.
In other words, get a tech to look at it.
Posted on Nov 12, 2011
What is the 59 co.error turn off turn on ? printer modle is hp 1215 colour laserjet pcl
I presume you are referring to the HP Model CP1215. The error 59.C0 error appears to refer to a mechanical error: Developer motor rotation error.
The recommended action is 1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize. 2. If the problem continues, contact HP Customer Support Center for technical assistance.
Your printer could be about 5 years old by now, so if this is a recurring problem you might be nearing the time for a replacement which might be less costly than taking your printer to be serviced.
You
Sep 09, 2014 | HP LaserJet CP1215 Color Printer
What is the 59 CO error?
59.C0 Developer motor rotation error
Sep 09, 2014 | HP CC377AABU Color Laserjet Cp1515n...
59 co error
59.xx error main motor failed to reach rotation speed in a given time:-
have you recently changed a toner cartridge? is it 3rd party?
remove all toner cartridges and then switch power on to printer - it should turn over then ask for toners to be inserted, if so the problem probably lies with a toner cartridge
if the toners prove to be ok then the issue may be the Developer lift plates ( front/rear) which tend to snap after a while not an expensive repair but time consuming..fuser units on this machine dont generally give main motor failures neither does the transfer belt. If I was attending this call I would definatly have a full set of spare toners and the dev lift plates to hand as this would most likely be the fix
Jan 16, 2014 | HP LaserJet 3600n Printer
59 co error
An error occurred with the developing
separation-drive assembly.
1. Check that the following connectors on
the driver PCA are seated correctly:
J403, J405, J213.
2. Check that connector J1020 on the DC
controller is seated correctly.
3. Check that connector J5008 on the
fuser motor is seated correctly.
4. Replace the developing separationdrive assembly.
5. Replace the memory-controller PCA.
6. Replace the fuser.
reseat fuser - something may be binding causing error
Oct 08, 2013 | HP COLOR LASERJET CP 3505 N PRINTER
Error co 59
Apr 18, 2009 | HP LaserJet 5550 Printer
HP LaserJet 2700n Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
