Question about KitchenAid KICU265HSS Kitchen Hood
Hoe to reset range hood after cleaning - KitchenAid KICU265HSS Kitchen Hood
Hoe do I clean the self cleaning oven?
try pushing the SELF CLEAN BUTTON.
Oct 31, 2015 | Kitchen Ranges
Light button blinking why
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Jun 22, 2014 | Broan-NuTone Broan Elite E661...
Removing blower motor
tap the fan on the shaft just a bit then clean the shaft with sand paper then carefully pull and rotate the fan off of the motor shaft = lock the motors rotor in a vice this make it a easy job. BUT don't damage the fan ! if it feels like it's not going to come off STOP. and search for you local electric motor repair shop with free testing. and ask him to pull it off fer ya, ask him how to oil this motor so you don't go threw this again. ?
Jay the pool pump motor repair guy in longwood Florida 32750
Feb 08, 2014 | KitchenAid Kitchen Ranges
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
Smeg KSE1V950X fan lights flash? Is this a filter cleaning issue and how do I reset it?
Yes this is a sign to clean the filters. Once they have been cleaned, it can be reset by pushing 2 buttons together at the same time - I just tried several combinations until they stopped flashing.
Sep 05, 2011 | Smeg KS9XSE Stainless Steel Kitchen Hood
My gas ran out of gas, it will not start. Hoe do I reset the fuel pump. The car will turn over but wont start.
I dont belive this car has a fuel pump reset button, Only a fuse and a relay check thim under the hood....fuse box
Jun 20, 2011 | 2000 Dodge Stratus
The range hood display is showing a "C". We had
Press and hold 'H' for 4 seconds - then press '+' which will reset the 'C' until the next cleaning reminder
Jan 01, 2011 | KitchenAid Architect® II KWCU405SSS...
We lost our instruction manuel-can someone show me hoe to do the cleaning process. Maytag Gemini double self-cleaning ovenor how can I get a new manuel?
http://www.kitchenaid.ca/assets/pdfs/literature/8113P363-60.PDF
http://www.kitchenaid.ca/assets/pdfs/literature/8113p293.pdf
Nov 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Kitchenaid hood wont allow reset of "C"
Try presing the "+" button for four seconds instead...
Mar 20, 2009 | KitchenAid KICU265HSS Kitchen Hood
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Feb 22, 2009 | KitchenAid KWCU205HSS Kitchen Hood
KitchenAid KICU265HSS Kitchen Hood Logo
62 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
