Question about Samsung SC-D353 Mini DV Digital Camcorder
Memory full new 4GB memory stick, and camera indicates memory full
3 Suggested Answers
charcois
  • 763 Answers
SOURCE: not recording
i have a camcorder just like yours. by the way im not using memory stick because its pretty easy to use a dv tape.
try to switch from the menu your storage device like dv to memory card or stick. format it to your camera and computer. hope that helps!
CHARCOIS
Posted on Jul 29, 2008
  • 50 Answers
SOURCE: I bought a new SanDisk
u can format ur memory stick by a pc then try again.....
Posted on Oct 30, 2009
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
Sony memory stick PRO duo 4gb card says memory full when empty
I would suggest formating the memory card through the options on your camera. If you reformat the memory card and you still get the same error then you have a bad card. Just like anything else the cards will break down internally over time.
Mar 07, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
When i turn on the camera, it says reinsert memory stick when it is already in the camera
Are you sure your camera can read a 4GB card? Only the very new and expensive cameras can. Read your manual. You may be limited to 1GB or 2GB cards.
Nov 12, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Sony dsc 200 8.1pixels
Camera does not support 4GB memory stick. Please use 2GB memory as maximum capacity.
Feb 25, 2009 | Sony Cybershot DSC-T200 Digital Camera
When i turn on my camera ,memory stick formatting error comes up
If it is Sony DSC-T200 camera then use maximum 2GB memory stick as it can not handle 4GB memory.
Delay when taking picture
2 things to be checked to rectify this delay.
what size of memory stick you are using. 1GB is fine, 2GB slower the camera and 4GB is more then enough.
Check memory stick, is it full with files? try to make more free space in memory stick.
perform "intialization" by selecting in camera menu.
Good luck.
Sep 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Samsung SC-D353 Mini DV Digital Camcorder Logo
14 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
