Question about PC Chips M825G Motherboard
Conexiones pc chips m825g - PC Chips M825G Motherboard
  • Rafeel Rivera Apr 26, 2014
    I added the connections
Pc chips m825 v 7.2 hit power button get three beeps every 30 seconds no video output changed processors no beeps still no video sounds like the computer isnt even trying to start any ideas??
check if you new processor is compatible for you mother board..if it is compatible, try reinsert the RAm or replaced it with a new RAM...hope it helps you..
Jul 26, 2011 | PC Chips M825G Motherboard
My ECS M825G motherboard has no battery? that I can find. Is that possible?
All motherboards have what we call a RTC battery. This means Real Time Clock which keeps the time and date and also the BIOS setting while the computer is turned off.
Look at the picture below for what the battery looks like and you should find it with ease >>>>
Regards.
Dec 09, 2010 | PC Chips M825G Motherboard
I cant find the audio an sound drivers to install
go to the manufacturers web site for the drivers or driver detective
May 09, 2010 | PC Chips M825G V9.2C KM266A P2400+(DURON...
No sound from a VIA KM266 PRO
maybe you did not instal the driver for it,you can from here http://www.radarsync.com/
Dec 06, 2009 | PC Chips M825G Motherboard
No video. The board does not recogonize the
try another monitor. try a PCI graphics card the on board video is likely bad.
Aug 03, 2009 | PC Chips M825G Motherboard
Problems with m825g
STOP!! Don't do it!
The M825G uses the KM266 Pro and , if the BIOS is correct, auto detect the CPU and its speed. That BIOS has a built-in OC utility, and that is why the jumpers are disabled.
The odds are you have an incompatible core. Just because the CPU fits the socket, doesn't mean it can work with the MB/chipset.
Check this link for that MB just to make sure.
http://www.cpu-upgrade.com/mb-PC_CHIPS/M825G(v9.2a).html
May 21, 2008 | PC Chips M825G Motherboard
M825G motherboard
Max ram is 2GB
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=24&LanID=0&DetailID=283&DetailName=Specification
Jan 06, 2008 | PC Chips M825G Motherboard
Cpu
THERE WILL BE A PUSH LEVER , JUST LIFT IT SLOWLY , THEN REMOVE YOUR CPU FAN AND NOW SLOWLY REMOVE THE CPU BY HOLDING ITS SIDES
Aug 24, 2007 | PC Chips M825G Motherboard
PC Chips M825G Motherboard Logo
955 people viewed this question
Top PC Chips Computers & Internet Experts
Thomas F. Schneider
Ekse
Alun Cox
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
