Question about Stihl Garden
Wood chips block oil - Stihl Garden
  • 27 Answers
You may have to clean the bare more often or the oiler is starting to go out
Posted on Mar 08, 2015
Where do I put the wood chips in?
this depends on the type of appliance you are using A smoker or a charcoal barbecue will use chunks instead of chips so I'll assume you have some brand of gas broiler that does not have a drawer or cavity for wood chips engineered into the design of the appliance.
In this instance you can soak chip overnight and loosely wrap them in aluminum foil. Place the loosely wrapped chips over a burner on the radiant tray or briquette tray so the heat is directly on the wood chips.
Close the hood and keep the other burner off or low so the heat on the wood chips soaked overnight causes them so smoke and not char. You need the wood chips over the flames so they smoke.
Oct 18, 2014 | Grilling
What is the cause for no chain lubricating oil
the pump isn't working or a wood chip is clogging the oil hole on the bar.
Oct 01, 2014 | McCulloch Garden
The spocket at the end of the guide bar keeps on blocking up with bits of slinters of wood and it jams up after 3 or 4 cuts and it is all brand new can u help me please cheers chris
you shouldn't have a problem with chips stopping the nose sprocket. make sure the saw is oiling well and that if the nose is grease-able it is greased. If that's all OK then I would look at the nose sprocket itself and make sure it didn't get pinched
Jan 28, 2013 | Garden
How do you burn the wood chips
The pre-soaked wood chips are placed in the cylindrical wood chip holder on the side of the unit and then inserted into the smoker above the wood chip tray. The wood chip tray must always be in place prior to loading the wood chip holder.
To further assist you, in case you have misplaced the Owner's Manual, I have included a link to it, that you can download and print for future reference. It also includes recipes.
http://www.appliancefactoryparts.com/content/pdfs/135884-1.pdf
To extend the use and longevity of this smoker, be sure to follow all the routine maintenance suggestions in the manual.
Hope this helped you to enjoy your smoker. Thanks for choosing FixYa.
Aug 05, 2011 | Masterbuilt 20070106 Electric Smoker
Cant get the chain oiler to pump oil. Can hear it pumping
If it has oil and is not pumping it, then it is probably blocked by a wood chip that fell in to the oil when you opened the cap.
You need to blow it out with air, backwards.
Aug 26, 2010 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
How do you remove the oil pan on 2001 grand prix
Remove the motor mount bolts on both sides. Using a jack & wood block, jack the engine high enough to allow the pan clearance enough for removal. Use wood blocks(4 by 4) at motor mounts & lower engine mounts onto the blocks. Lower & remove jack & block at jack. Remove pan bolts & carefully using a large pry bar or common screwdriver pry the pan away from engine . Good luck!
Apr 01, 2010 | 2001 Pontiac Grand Prix
How difficult is replacing an engine pan and gasket on 95 ford f150 4.9 litre 2wd
  1. Drain the oil and the coolant
  1. Raise the vehicle on a lift. Disconnect the battery to starter relay cable at the starter motor and remove the bolts and starter motor.
  1. Remove the engine front support insulator-to-support bracket nuts and washers on both supports. Raise the front of the engine with a transmission jack and wood block and place thick wood blocks between the front mounts and engine. Lower the engine and remove the transmission jack.
  1. Remove the oil pan attaching bolts.
  1. Remove two bolts securing oil pump and screen bolts and drop them in the pan
  1. Remove oil pan
Mar 17, 2010 | 1995 Ford F150 Styleside Regular Cab
How can i get the oil pan off w/out taking the motor out of the car
Loosen motor mount bolts holding engine to mounts. Raise engine enough to remove pan. use 4x4 wood blocks to hold engine up so you can let it down on the blocks. Use wood block between jack & engine when lifting!
Sep 12, 2009 | 2000 Pontiac Firebird
Poulan 210 Pro not oiling chain
Make sure the oil port doesn't have a chip of wood blocking it.
Jan 30, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Engine mounts
you can jack on the oil pan if you use a block of wood in between to spread out the weight across the oil pan, likewise you can jack on the transmission pan with a block of wood in between.
Nov 05, 2008 | 1997 Chevrolet Malibu
Garden Logo
23 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
