Question about Broan-NuTone N671 Nautilus Ceiling Fan
How do I remove the grate off from bathroom exhaust celing fan
Hpm bathroom exhaust ceiling fan, the grate is dirty & I want to know how I can safely take it off & clean it. There are no screws on the outside, it is flush to the ceiling.
SOURCE: Noisey 8 x8 Broan Bathroom Exhaust Fan (With Light) (7 years old)
Mine was doing the same thing. I found it was coated with dust.
I took the blower out [unplugged it, and removed the single screw holding it to the box], took the face plate off [removed 4 or five screws] brushed the squirrel-cage fan blades using a narrow, long and stiff bristled brush, and reassembled it [used care to align the small plastic axle on the flap valve ] and reinstalled it. The vibration was greatly lessened and the fan was about as quiet as it had ever been.
Posted on Feb 02, 2009
  • 360 Answers
SOURCE: Can't seem to remove the exhaust fan - I don't see any screws?
on most of these units, there are tabs that hold one side in place and across from them is a detent that needs to be physically moved out of the way for the motor to swing down (uses the tabs as hinges), once the motor mounting plate swings down the tabs will slide out of the slots and the motor is out of the unit.
please take the time to give this solution a fix ya rating.
clarkco
Posted on Mar 19, 2009
Bat1956
  • 585 Answers
SOURCE: Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
Posted on May 16, 2009
  • 72 Answers
SOURCE: have a broan n688 ceiling exhaust fan in bathroom
First turn the power to the fan OFF. Take it down from the ceiling by removing the screws holding the cover on. Then remove the screws holding it to the ceiling. Then unscrew the screw caps that twist (connect) the wires from fan motor to the house wiring. Do a general clean up on the fan. Use an old paint brush to get in the hard to get at places. Rotate the fan by hand. If it does not rotate freely, put some oil on the shaft where it goes into the motor, and put some on where the shaft comes out the back. If it still does not rotate freely, buy a replacement and install it.
Posted on Oct 07, 2009
maintenacemi
  • 95 Answers
SOURCE: My bathroom exhaust fan makes a clicking noise,
fan blades touching sides of housing,also runs caused by back draught
Posted on Nov 18, 2009
Both the fan and the light stop working. What are the first things to try?
Good way of asking for help!-- Thank you!
First make sure the circuit is not tripped at the Circuit Breaker--
(Are other lights on the same circuit still working OK?)
You will need to verify which breaker controls the voltage to this fan--
and you will need to turn the breaker OFF, while dismantling the fixtures.
Can you communicate with someone at the Breaker Box, while you work safely?
Have them turn the circuit on when you are safe and ready -- and reading voltage, etc.
Next-- Do you have a dimmer switch, (or just a wall switch) on the wall?
Do you know if the power is supplied to the ceiling, thru that wall switch?
If so, check to see if the dimmer or the switch has power coming in and out at the wall, and heading up the ceiling supply wire.
If the power is supplied at the ceiling, then you are going to have to get a safe ladder, and remember Ladder safety rules!
The tough part, is getting the heavy fan and light assembly safely down, where you can make some voltage readings at the supply circuit wires at the ceiling--
Maybe you have found a loose wire nut by now?
Or maybe a defective dimmer or wall switch?
Or what are you observing at the junction box, and the fan motor now?
Tell us more-- and we'll see if we can help yo to the next step.
Mack B,
Jan 18, 2011 | Hunter Ceiling Fan Control Switch
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
I have an old - 10+ yr broan heater fan that went out in the bathroom. Can i get a new broan that would fit the old box in the celing?
yes, you should be able to find one..they may have changed the cover but the box should be the same... i know home depot and lowes carries some broan products... i fnot go online and search broan exhaust fans and see if you can locate... it may take a little searching but if it is the sueare type still common to find.... good luck to you ..
Jan 13, 2011 | Broan-NuTone Heating & Cooling
There is a part our bathroom ceiling that my husband has spackled 2x and painted and the paint bubbles. We have a fan in there. It started bubbling within a month of him redoing it last time. Any...
if it's around the fan then mabey the fan exhaust pipe is not connected .If it's in the attic you can go up there and checkbut if it's between floors you will have to pull the fan down from inside and check. It sounds like your celing keeps getting moisture from the underside of the paint
Apr 10, 2010 | Home
Have a broan n688 ceiling exhaust fan in bathroom and now it takes a couple of minutes to actually start, finally making a whirring noise before coming on. Solution?
Oct 07, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Hampton Bay remote for ceiling fan caused an electrical fire
We just installed this fan and within 1 day the electrical wires in the receiver burned and would have caught fire had it not been caught!!!
Jan 07, 2009 | Universal Remote Control Hampton Bay...
Encon celing fan 3 speed with globe light.
I have the same fan and same problem, did you find a source for the part.
jack smithjm4@gmail.com
Oct 10, 2007 | Encon Industries 72009 SWIRL Ceiling Fan
Broan-NuTone N671 Nautilus Ceiling Fan Logo
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
