Question about Coleman Powermate 02 - Gallon Air Compressor
Need to add compressor oil - Coleman Powermate 02 - Gallon Air Compressor
How much oil a/c compresor need on a 1997 jimmr
You do not add oil to an automotive A/C compressor. When you do a refill with a proper coolant, it will have any necessary lubricants.
Apr 25, 2015 | 1997 GMC Jimmy
2003 jeep liberty air conditioning oil capacity
If the compressor is dry of oil (new compressors will either be shipped with or without oil) and you need to add oil you can never go wrong by adding three ounces. Once the compressor is installed turn it by hand several times. Then install the belt and add freon.
Aug 07, 2012 | 2003 Jeep Liberty
NEW AC COMPRESSOR MAKING NOISE
Did you add the correct amount of oil to the compressor? Is it overcharged? Did you evacuate all the air with a vacuum pump before charging? Was the fixed orifice replaced? If you are sure you did the install right and the oil and charge are correct you have another defective compressor
Jan 25, 2012 | 2005 Chrysler Town & Country
Need to know how much compressor oil to add to anew compressor? lost all paper work
You will add 2oz of oil to compressor then stand it up on the pulley so oil lubes front seal. let it sit for 10 min like that then install, its a good thing to replace the dryer alot of parts places make you replace it inorder to get warranty for compressor. if you replace the dryer then add 1oz inside of that, after you put it togther and line are connected spin compressor by hand 15 times to help get some oil out of compressor and into lines, make sure to vacuum the system for 1/2 hour to get air and moisture out of system. a vacuum pump is needed to do this. good day.
Aug 12, 2011 | Geo Tracker Cars & Trucks
I am doing a full evacuation and recharger on a 1995 buick lesabre and I need to know how much compressor oil and the viscosity of the replacement oil Can anyone help?
r-134, 39 oz of freon, pag 150 oil, 8 oz oil, now that is the capacity for a new compressor and systen cleaned, or you need to drain yours old compressor and add half to the compressor and half into the accumalator/drier to have the correct oil amount in the system.
May 21, 2011 | 1995 Buick LeSabre
Replacing a/c compressor and accumulater on 97 chev lumina.new compressor says add 180cc pag oil.do i need to add oil to accumulater?
Usually an ounce is more than enough to add to the accumulator. Same thing if you where to replace the condensor or evaporator.
If you wanted you could dump the oil from the old accumulator into a cup and then add that same amount to the new one but an ounce would be the norm.
May 03, 2011 | 1997 Chevrolet Lumina
How much oil do i put in my 2000 dodge stratus air conditioner compressor?
Most the time its 8 oz,, need to check with the seller and see the specs on compressor,it should say on ac compressor
Aug 22, 2010 | 2000 Dodge Stratus
Im installing a new a/c compressor and i need to add oil and i need to know how much. Its a 1997 suburban with the rear evaporater.
11 OZ of PAG 150 oil Follow Compressor instructions to see how much to add to New Compressor and the balance should be poured into the NEW Accumulator and change the orifice tube in the front near Y split after the condensor on the high pressure side.
Jul 29, 2010 | 1997 Chevrolet Suburban
Coleman Powermate 02 - Gallon  Air Compressor Logo
18 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
