Question about Refrigerators
I CHANGED THE FILTER AND SET THE SETTINGS AND IT BEGAN TO WORK A FEW HOURS LATER THE DISPLAY WAS SHOWING ER NOW THE REFRIG. IS NOT COLD AND THE FREEZER IS NOT WORKING AND THE ICEMAKER IS NOT WORKING ALL IN ALL THE REFRIG. IS NOT IN WORKING COND. I HAVE A KENMORE ELITE MODEL795.7756*,7757* WITH BOTTOM FREEZER
  • lpestes May 20, 2009
    because I already called for service but they cannot come out for one week. in the mean time i'm having to throw out everything in my refrig and in my freezer it is going to be very costly
    tyhankyou anyway
  • Anonymous May 21, 2009
    THANKYOU FOR THE ADVICE I ONLY HAVE ONE QUESTION ,WHO OR WHAT IS LG.? I'M SORRY I DON'T KNOW OR EVEN HAVE A NUMBER . THANKYOU
  • 864 Answers
If this is the Kenmore french door model with bottom freezer and ice and water in the door made by LG it could be that the mother board has failed.  Call for service and hope that warranty is still in effect.
Posted on May 20, 2009
  • John Morganti May 20, 2009
    About your comment concerning loss of food.  Here is what I did for the week or so it took to get my fridge fixed. My freezer was not broken so the frozen food was OK.  I bought a small under counter sized fridge for $150 to keep basics cold.  Since my repair was under warranty I called LG and complained about the time it took to fix and the loss of food.  They sent me a check for $150 automatically.  So in my case the cost of the small fridge was covered.  You do not have to buy a fridge, just call LG and make a stink about the lost food.  Tell them how much it was worth and see what you can get.  I think $150 is their standard response to this action.  Good luck.
  • John Morganti May 21, 2009
    In answer to Guest who asked about LG:
    LG Electronics
    For Audio/Video/TV, Computer Products, Home AppliancesU.S.A. Corporate Headquarters
    1000 Sylvan Avenue
    Englewood Cliffs, NJ 07632
    Toll Free: (800) 243-0000
    www.lg.com
Stove clok is not showing time
try pressing the clock button after setting the clock .^-^
Mar 09, 2015 | Kenmore Kitchen Ranges
Whirlpool conquest side by side. Ice began melting and red light for filter replacement was on. I changed the filter but it didn't seem to fix the issue. Few days later everything began working fine but...
Turn the temp control to max, does the compressor come on? If yes feel the discharge line at the back of the compressor, is it nice and cold? If yes you can eliminate the simple items, make sure all the fans are working inside the fridge and at the rear of the unit. Check to make sure the defrost drain/trap are clear. Let it run for a while, then drop the temp to the usual setting it, and see what happens.
Feb 26, 2015 | Whirlpool Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
GE Profile Arctica Refrigerator Displays OFF PSS29NGNAWW
Sadly i would say the board is malfunctioning and needs replacement. There is nothing in the fridge/ freezer that if malfunctions can cause that.
Sep 21, 2009 | GE Profile PCF25PGW Side by Side...
Door display shows ER WITH A UPSIDE DOWN HP. I turn the power off and back on and the display goes back to normal but after several hours it goes back to where the only thing on the display is the ER PH...
That stands for "error defrost heater"
Even though the refrigerator has gone through a defrost cycle, if a temp sensor does not reach a set temp within an hour, that error will display. You may have a bad defrost heater, defrost relay, thermal fuse, blocked defrost drain,..... something wrong with the defrost system anyway.
Aug 03, 2009 | LG LFX25960ST Stainless Steel French Door...
Clock time always goes back one hour after setting it.
Check on the general set up/ clock, what zone is set and put east, mis or west deppending where are you located, turn on the automatic clock or select a news channel where the decices will check the update time.
Nov 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Refrigerator freezes food
sounds like might be a cold control issue, not cyclying on/off. if correct you dairy is good judge, so id assume that your ice cream is FROZEN SOLID. try turning down refrig temp control this will reduse run time(if working at all)
Feb 24, 2008 | Refrigerators
Refrigerators Logo
188 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
