Question about Konica Minolta DiMAGE A200 Digital Camera
Anti shake locked on - Konica Minolta DiMAGE A200 Digital Camera
My 2011 MKX front wheels start shaking badly, then the brakes lock up. The anti-traction light is on and the collision avoidance system says it is not available.
if the shaking starts at around 30 mph have a wheel alignment done as it indicates a castor wobble problem
have the front end and suspension checked for worn steering joints , ball joints and wheel bearings
Oct 24, 2017 | Cars & Trucks
I dropped my konica minolta dimage a200 and now when i turn it on the screen shakes and anti-shake does not work
The tracking servo motors and associated gears are damaged or misaligned. The purpose of these servos are to automatically adjust the lens positioning so that it seems the camera is almost stationary. When the anti shake is enabled, the lens locks onto a target and if the target moves, the servos move the lens to compensate for the offset. If you are experiencing screen shaking it means that the lens is trying to adjust but cannot because the servo system is damaged. It's quite possible that only one servo motor is functioning and the other is loose. It will require in shop repair.
Nov 10, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
Strange vibration at the pedal when breaks lock
sounds like warped rotors, if the steering wheel also shakes then that would tell me its in the front, replace the front pads and rotors that will solve your problem.dont try resurfacing youll just have pulsating brakes again in a month or two.
Jan 08, 2010 | 2006 Audi A4
The images that I take are blurred
On almost all newer cameras there is an anti-shake feature. AND it is almost always turned off by default. Go through your camera menus and look for anti blurr or anti shake, the icon is usually a hand or person with lines "moving" outside it (to represent shaking). Good Luck!
Nov 10, 2009 | Canon Cameras
Camera turns on with a bit of a tremble but shutter locks
I have an 5D with the same problem, It looks like the Anti shake does not initialize properly, The only bypass I found that worked (except for a real repair) is to set the display light timeout for 5 seconds, The standby timout for 1 minute, Turn the camera off, and on again, Wait for 5 sec then the display goes blank, wait for 1 minute then the camera goes in standby, (light from CF card flashed red 1 time) Then touch any button to re-activate the camera and... voila... everything works, including taking normal pictures and the anti-shake !!! So it only takes a minute everytime to startup..
Jun 05, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Help
check the brake fluid level and if it is at the proper level then there is a problem with either your sensor or the brakes themselves check the pads first does the pedal shake when you press the brakes?
Oct 06, 2008 | 1997 Ford Expedition
Shaking while braking at speeds 40 mph +
Anti-lock brakes mean the car shakes when the brake is applied. Try pumping the brakes.
May 15, 2008 | 1996 Chevrolet Classic
ANTI-SHAKE TURNED OFF
  • Switch camera on
  • Select Menu Button
  • Menu item 1
  • Use controller to move down to anti-shake
  • Use controller to move right
  • select i) Disp + Exp ii) Exp only iii) Of
Go to http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z5/Z5_OM_E_.pdf for a Z5 manual
Jan 26, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE A200 Digital Camera Logo
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
