Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson printer only printers every other line
Epson xp-300 with all new cartridges...when it prints it only prints every other line. I tried different documents, same result. I uninstalled the printer, reinstalled the printer, rebooted the printer...same results...test page prints fine...tried printing excel doc's and same results
5 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Posted on Jan 08, 2008
printech
  • 159 Answers
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
SOURCE: Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Posted on Feb 20, 2009
Basti
  • 1447 Answers
SOURCE: Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Posted on Sep 20, 2012
Installed new ink cartridges. noyw when I try to print I get blank pages
FAQs - Epson XP-410, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
Epson[ Answer ]; How do I print with black ink when a color cartridge is expended? [ Answer ]; I see the message Printer is Offline when I try to print with a wireless ...
Epson XP-400, Top FAQs - Technical Support - Epson ...
Epson[ Answer ]; What should I do if my product is printing blank pages? [ Answer ]; I don'thave the CD that came with my product. How do I install the software for my ...
Epson XP-810, Top FAQs - Technical Support - Epson ...
Epson
Feb 05, 2016 | Epson Expression XP 410 Wireless Printer
Epson XP312 will not print greeting cards of 380 micron. Previous printers never had a problem.
Epson XP-300, Top FAQs - Technical Support - Epson ...
EpsonWhat should I do if my product is printing blank pages? [ Answer ]; I ... [ Answer ]; Can the printer still print if an ink cartridge is expended or not installed? [ Answer ] ...Missing: greeting380micron
Troubleshooting printing, scanning and wireless ... - Epson
Nov 29, 2015 | Epson Office Equipment & Supplies
Epson LX 300 printer. every line, starting
Try to check your printerhead it could be damage due to over use or old printerhead. Just replace your printerhead to print it normal.
May 29, 2010 | Epson LX-300 Matrix Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
159 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
