Question about LG Heating & Cooling
Air conditioner compressor keeps shutting down
I have a LG 1.5 tons Split A/C and have noticed that the compressor keeps shutting down when the temperature outside is above 40 celcius especially in the afternoon. For example, when i turn on the A/C and set the temp to 28 the A/C cools for about half hour then turns off without reaching the desired temp and then the compressor does not come back on for 30-45 mins. What is causing this is? is it a faulty compressor?? I have also got the capacitor replaced and it still did not solve the problem. I have another Haier 1 ton A/C and this works fine in the same conditions. Please help and thanks in advance.
  • abhishek_ban May 19, 2009
    The fan is always running even when the compressor is off so it can be due that. How can i check the oil in the compressor??
    President:
  • 2,559 Answers
This is due to thermal overload,Which can be caused by low oil in the compressor,the fan has stopped running on the unit outside,Dirty coils,or just a worn out compressor.Although this is thermal overload,It has nothing to do with outside temperature,But rather the internal temperature of the compressor itself.
Posted on May 19, 2009
  • Randy Hough
    Randy Hough May 19, 2009
    The best way is to have the unit totally evacuated and vacuumed,Then have new oil added and recharged with refrigerant.Since the Thermal overload can be caused by low oil,a partially restricted line,A loose connection in the wiring on the compressor,or the fan not working or working in the wrong direction(When the fan is working correctly,Air should be blowing out the top of the outside unit when the A/C is in cooling mode).
    If you can supply the results from previous test done,Such as the refrigerant charge pressure and at what ambient temperature,Head pressure reading(Pressure on the high side),fan direction,Etc.....
    I would be able to provide a more detailed solution.
How may capacitors are there in LG split ac 1.5 ton unit
At least 3. 1 on the inside unit fan, 1 on the outside unit fan and 1 on the compressor. The outside unit may have both in a single chassis.
Aug 15, 2016 | LG Electronic Window Air Conditioner
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My LG Split 1 ton Continue poor working with under voltage 180V (Due to Long distance Transformer), Once its capacitor have to change this summer. Now i arrange Stabilizer which give 230V. Before...
Unfortunately, there is not a great deal of information about LG splits available, but is you are talking $12,000 to to repair, then it is much cheaper to replace since a two ton complete is less that half that amount.
Jun 30, 2011 | Heating & Cooling
Hi, I have to replace the capacitor (35 +2 microfarad) for my LG 1 ton, split Air Conditioner. The LG service guys had told that this model is nomore available with them. They tried some alternatives,...
Are you sure the capacitor is faulty? You can go up in U,F's but not down and if it is the capacitor it will work. For instance, you can use a 40x5. The larger number is to start the compressor ad the lower is for the outdoor fan motor. I know nothing of India, but if you have any appliance parts houses, they will have them, or can order one for you. A capacitor for that unit should be easy to find if you have parts places for appliance's there. Good Luck, and keep me posted. You can order on on the Internet from the States also. They are inexpensive, the shipping charges may cost the most. Have it checked out to make sure is is faulty. If it is swollen or deformed, or leaking oil, its bad. If not, take it to a repair place for appliance parts and check it for dead shorts or open windings..
Shastalaker7
A/C,& Heating Contractor.
Mar 26, 2011 | Heating & Cooling
5 ton split LG UNIT brand new about 1 year old.
Look up the term BLACK DEATH.
90-100 psi is very high on the low side.
Without spending too much time,I would pull a vacuum to -28 inch of mercury and let it sit over night.
Monitor the manifold garage for leak. (rise of inch of mercury)
My bet is the low quality LG compressor's worn out metal part is in the condenser.
Blockage will increase the low side PSI.
You can buy HVAC blow out can/chemical to clean line before you vac and fill the refrigerant.
Please let me know what's you founding is on reply.
Jul 11, 2010 | Whirlwind FH-778 Air Conditioner
Problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My 1.5 ton,LG split AC shuts off rather
Hello
First the foam insulation is not just for looks,you will have some loss of cooling on the unit,the larger cooper line needs to be insulated,the small one does not.The large line is the suction line,the small one the liquid line.
Voltage,168 is low,sounds like a 208 volt unit or 220 volt.running at 168 or 198 ac volts is going to raise the amperage causing the compressor to run hot and work harder and soon burn up,And cause it to trip the breaker or shut itsself down on high heat.Your going to need to get that voltage fixed.I dont know why it needs a stabilizer if the unit was sized correctly it shouldnt need one.
Hope this helps.
Apr 14, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
My LG intelloair 1.5 ton split a/c's compressor not working.
check the compressor's start/run capacitor. if it is swelled at the top, where the connectors are, replace it.
Apr 04, 2010 | Heating & Cooling
The remote control operates intermittenly and there is no other way to shut down the AC
You have a ton and 1/2 split that's running all the time and problems with the remote?I am sure you have changed batteries if it has them. I would shut it off at the breaker until you can have the remote checked out or replaced. I know this would be a pain, to do, but you may have to until the remote is working right. Good Luck
Shastalaker7
Nov 06, 2009 | LG LS-K1830CL Cool Mini Split Air...
Compressor keeps shutting off after 30mins or so
The system may be going into cool down mode or thermal over load if the temperature is 104 degrees fahrenheit or above since the compressor will shut down if the internal temperature reaches 165 degrees.This could also be from low oil in the compressor.
May 19, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
Heating & Cooling Logo
2,749 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
