Question about Watches
Change day on river island watches
Cant change date and day on watch
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
  • 37 Answers
SOURCE: HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Posted on Nov 24, 2008
escapement
  • 2334 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
escapement
  • 2334 Answers
SOURCE: how do i change teh date on my tag watch with out
If you pull out crown carefuly, you will notice there are two clicks. The first one is for adjusting calendar (day or/and date). Next one is for moving hands. Pull out to the first click and adjust the date by turning the crown.
Rate me, please.
Posted on Aug 04, 2009
SOURCE: how to change the date and week?
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
Hope this helps as it took me using the correct movement number on the url in the previous post (for Calibre 8700 the movement number is "E870").
Posted on Mar 23, 2010
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Coleman watch is on but cant change the time
Try this site:
http://www.ehow.com/how_8204646_set-date-coleman-watch.html
Jan 21, 2013 | Watches
Cant change the date
I am assuming the day changes but not the date. There is a halfway setting on the stem you pull two clicks to set time , one click to set day/date, turn one way for day of the week other way for date. If your actual date is sticking you can try going round and round with the hands (takes awhile) to set it! I have noticed the date is the first thing that goes on these watches. If that does not work it will have to be repaired by a watch repairman. hope that helps:)
Aug 28, 2011 | Watches
My analog Guess watch has a date display only (no day). I have re-set the date over and over, but it changes the date at noon instead of at midnight.
Your problem is caused by the fact that the watch is 12 hours out of step.
Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
(if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
Jun 04, 2011 | Guess G85675G WristwWatch
I have a guess steel watch , and i have set my date and time right , but i cant put the day right , so monday or tuesdag for example.
Advance the watch time 24 hours to change to the next day. keep turning until it reaches the corect day of the week, then reset the correct time and date.
Nov 14, 2010 | Guess Watches
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
Day date changes midday 12:00 PM, not midnight 12:00 AM. How to change this?
Your watch thinks your noon is midnight.
Wind the hands forward 12 hours and the date change will be at midnight. You will have to re-set the date if it gains a day when doing this.
May 28, 2010 | Bulova Watch
Change day on dial
Pull out the crown to the first click- the watch is in day-date setting mode. Turn the crown one way- the date will change. Turn the crown another way- the day will change.
Rate me, please.
Mar 21, 2009 | Guess Collection Textured Dial Watch
How do I set time on digital Joe Boxer A126-03?
Press the mode button 3 times. Use the lap/rst button to switch to the min/hr/date field you want to change. Use the st./stp button to change values. When finished, hit the mode button again.
Mar 11, 2009 | Tommy Bahama Islander Dual Time Date Watch...
Change day
The trick is to turn the ring to the "Date" setting, Pull the stem out once for the Month and Date. Pull the stem out (hard, but gently) a second time for the Day of the week. Each pull will be confirmed by a 'beep. Be persistent and good luck.
Oct 15, 2007 | Timex Men's Black Reef Gear i-Control...
Watches Logo
241 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
