Question about Dremel 1800-01 Scroll Station 18" Variable Speed
Dremel Scrollstation 1800 motor fault
Switching on cuts-out the electrical supply. It seems to be the motor that's at fault (i.e doesn't blow when motor disconnected). I've stripped the motor but can see no physical problem with the armature windings. Any ideas what could be wrong, please? Also, it has a curious ring shaped device in its circuitry that fits behind the commutator that I've not seen on other motors - can someone tell me what this does, please? Any tips as to how I might check "electrically" for short or earth fault would be much appreciated. Thanks.
There seems be problems with the electrical systems of the Dremel 1800 scroll stations (had same problem)
Speedcontroller burns out and DC motor gets hit by Main AC voltage.
Earth leakige due to low resistance between DC motor Rotor and earth (flowing current to earth)
Measure rotor copper connections to earth to check for low resistance, should be very high.
Biggest problem is that the main metal body under full main voltage comes and this is a dangerous situation!!!!!!!
All to fix is to repalce (both) fauly parts,
Motor Controller and DC motor
Hope this helps
Posted on Nov 01, 2009
Mantis electric tiller runs for about 20 seconds then cuts out. Hit circuit breaker, runs then cuts out again and smells like it's burning. Went through all the troubleshooting and no warranty. Help!
It probably smells like it is burning because that is exactly what is happening. Persisting is likely to make things worse, if it is possible for things to be worse.
As the circuit breaker is tripping it is likely the fault is electrical. There probably isn't much electrical to go wrong apart from the motor, a switch and some wiring. A motor fault would seem likely unless the mechanical drive is so very tight it is overloading the motor.
Clearly the machine must be dismantled and checked through by someone competent to do so. The supplied troubleshooting guide is not likely to be much help as they have to be safety-conscious, they tend only to deal with external issues.
Jun 23, 2016 | Mantis Garden
How can i test if it's brushes or speed switch fault on Piggin Dremel
Problem sounds like the switch. Easy to replace and a lot cheaper than a new Dremel. One other thing comes to mind. Blow out the Dremel with compressed air. I could be to dusty and overheating.
Aug 28, 2014 | Dremel Tools & Hardware - Others
Dremel multi max stops when pressure is applyed
I took mine apart due to the same reason. Seems like the yoke that fits over the drive bearing is worn or bent to oversize so that it doesn't make a complete rotation. Hence, a very small or no cutting swath. You can replace the drive head for about 22 bucks plus shipping, (dremel parts) or go to Home Depot and get another one for 70 bucks plus tax. Or do as I did and go to harbor freight and get a Chicago Electric multi tool for about 30 bucks. It works fine. I'm not a professional and don't need a 200 dollar one.
May 07, 2014 | Dremel Multi Max Kit
Opel corsa bakkie 2002 . motor cuts out without warning
check crank position / cam position sensor s / wiring
run the fault codes first
Apr 25, 2017 | Cars & Trucks
Dremel 1800 scroll saw manual
Here is a list of what you can get. If it is not listed there then there is a spot at the bottom of the page to request a manual.
Dremel manuals
Aug 22, 2012 | Dremel 1800-01 Scroll Station 18" Variable...
Hi, My drill(Dremel) just doesn't turn on. The sliding switch moves, but nothing happens. The switch moves losley too. It seems dead! I wasn't present when it broke. I do not know any details on what...
With the machine unplugged, check the motor brushes. They may be worn.
I have not had success doing any other repairs to the motor part of a Dremel. I do know they have a service center. Go here for more info:
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
Thanks for your question at FixYa.com
Jan 15, 2010 | Drills
I have a DREMEL 10.8 Volt rechargable. While using it, suddenly the motor shaft started feely spinning inside of the the entire mechanism that holds the bit. It is not a couling problem. The motor shaft...
I love Dremel I really, do but they have issues like all tools.
I know how to fix it but there is no places that sells the parts... If you can find one that had its motor blow, like from a friend, neighbor, or co-worker, you can swap out the parts your self...
I personally only buy craftsman. You can not beat a good warranty.
Jan 10, 2010 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel motor dead. Unit bought new, used twice; once to cut through a small screw with cutting wheel, and once to cut through the thin metal of a small wire shelf. Tool performed perfectly both times...
absolutely astounding! Had my Dremmel for 10 years and abuse it and use it it has been wet and its out in the shed. Never had a days trouble.
Now when it was in the case was the case shut? My thoughts are mice piddle which if it gets inside will corrode everything. I say this because a bigger drill of mine got damaged in that way. No external signs of damage but when opened the damage was there and it could also be then smelled.
My only other thoughts on this is to get you to check the plug to see a wire has not pulled off, after that I would suspect the dremmel switch has a fault.
all shots in the dark! but have to start somewhere when you are riding blind.
Thanks for using FIXYA
Oct 11, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
Dremel 395 Type 2
REFERENCE M/N: 395 - Type 3 - Dremel does not have the parts listing on their site for some reason. I actually have the original I saved from 1988!
The part number for the Nylon Coupler is:
Illustration Code Number: 5
Description: Flex Coupling
Part Number: 529430970
This is all from Drawing (Form) Number:5296074 10-88
Jun 15, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel 1800-01 Scroll Station 18" Variable Speed Logo
444 people viewed this question
Top Dremel Drills Experts
richie46
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
