Question about Karcher 2500 PSI Pressure Washer
Honda GC160 5HP engine
I am replacing the piston and rings in this engine and need the torque spec for the rod cap bolts and I need help in recognizing the timing mark indicator on the overhead cam for the timing belt alignment with the crankshaft.
Gene, Decatur Indiana
Broken timing Gear.
What would cause this,
Posted on Aug 27, 2011
  • 211 Answers
Hi
9 ft-lbs .Now about the timing marks.If you look at the top you can see 4 gears:2 balancer shafts,the crank shaft and the cam shaft.There are two possibilities for timing marks:the first is balancer to- camshaft timing marks,balancer-to- balancer timing marks and the second one iscamshaft-to crankshaft timing marks and balancer-to-balancer timing marks.Ignition coil-to-flyweel gap is 0.016 inch.
best regards savumihai71
Posted on Feb 15, 2009
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
What is the engine bolts torque specs used
Selan Shaheed, probably best to get a workshop manual for that data.....that needs to be correct to ensure engine does not fail....Haynes may have one that you can access on line but you will need to search for it. I found several URLs that offer access to an on line PDF but the require you to fegister
Jul 12, 2015 | Cars & Trucks
What the torque specs. For a 2002chevys10 4.3vortex mains and rod bearing
Torque Specs Database
Type: Dim: Length: Head: Nut Grade: 20 Ft-Lbs 240 In-Lbs 27.12 N-m Connects: Connecting Rod To Engine Block Years: All Vote Record: Vote Note: Vortec - Rod Cap Nuts - 2 Steps: 20 FtLbs; +70degs
http://ww2.justanswer.com/uploads/ZZdaryl/2009-06-14_153454_torque.pdf
Main Bearing Cap Bolt 4.3L Step 1 15 ft lbs (20) Step 2 Additional 73 Degrees
i don't know if that's correct for main bearing caps since another link states it's much higher
4 3 Vortec Piston Specs eHow
hopefully a GM guy will chime in to confirm the main bearing torque
the rod bearing torques are the same on all the other links
Mar 25, 2015 | 2002 Chevrolet S-10
I am trying to find out the torque spec for a 1999 honda accord 3.2 vtec connecting rod and main bearing
From Helms manual (factory shop manual)
Rod, FI engine: 34 lbs
Rod, Carb engine: 23 lbs
(I use blue thread locker on rod caps)
Crank caps: 51 lbs. (oil threads and under bolt head)
Mar 05, 2015 | 1999 Honda Accord
I am looking for torque specs on a 91 honda prelude 2.1l.I need specs and sequence for the main bearing caps and rod bearings
the specs for the 1991 prelude with a 2.1 engine are, the connecting rod caps are 34 ftlbs and the main bearing cap are 49 ft lbs, hope this helps,
Sep 10, 2010 | Honda Prelude Cars & Trucks
2004 mazda 6 3.0L V6 main bearing caps(bootom end) has 16 bolts need torgue specs please!
Okay, the main bearing caps only have 10 bolts, i think your looking for the connecting rod caps, they have 16 bolts, i will list them both, theres a tightening sequnce for the main bearing caps, these are the caps that hold the crankshaft to the engine block, the connecting rod caps hold the pistons to the crank and they have 16 nuts,For a 2004 mazda 6 with the 3.0 engine the torque specs are as follows.
Connecting rod bolts step 1) 19.2 - 23.6 ft lbs.
step 2) tighten an additional 80 - 100 degrees
Main bearing caps step 1) 32.5 - 33.9 ft. lbs.
step 2) tighten an additional 175 -185 degrees.
heres a diagram for main caps to tighten in order.
Aug 20, 2010 | 2003 Mazda Mazda6
What are the torque specs for the piston rods and head bolts
The connecting rod bearing cap nut on a four cylinder is 40 ft-lbs. The cylinder head bolts are torqued in four steps.1-45 ft-lbs 2-65 ft-lbs 3-65 ft-lbs 4 1/4 additional turn after reaching torque specification. On the V-6 & V-8 the connecting rod cap nuts at 45 ft-lbs and the headbolts are torqued in two steps 1-50 ft-lbs and 2-105 ft-lbs. Hope this will help you.
May 16, 2010 | 1995 Dodge Dakota
Torque specs
2002 2.0L Duratech.
Don't have 2004 2.3L
  • NOTE: Use new connecting rod bearing cap bolts.
    NOTE: Do not fully tighten the connecting rod bearing cap bolts at this stage.
    Install the bearing caps.
  • Rotate the crankshaft through 180 degrees and insert pistons 2 and 3.
  • Position the corresponding bearing shells, clean and free of oil, into the connecting rod and the connecting rod bearing cap.
  • Coat the inner side of the bearing shells with engine oil.
  1. NOTE: The crankshaft must rotate freely, if necessary check and adjust the bearing clearances.
    Tighten the main bearing and connecting rod bearing bolts.
    1. Tighten the main bearing bolts in two stages.
      • Stage 1: 25 Nm.
      • Stage 2: 60 degrees.
    1. Tighten the connecting rod bearing bolts in two stages.
      • Stage 1: 35 Nm.
      • Stage 2: 90 degrees.
Apr 28, 2009 | 2004 Ford Focus
Karcher 2500 PSI Pressure Washer Logo
3,428 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
