Question about Sharp R-510HW Microwave Oven
On Sharp R-309YK R309 Series 1.1 Cubic Feet 1000-watt have light come on with door open
Have light come on with door open
What is the Interior Cubic Foot capacity and the wattage of my GE Profile Microwave JE1540WW02?
GE oven model JE1540WW02 has a capacity of 1.5 cubic feet, and cooking power of 1000 watts. The power is listed on page 14 of the owner's manual here.
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | GE Microwave Ovens
What is the cubic feet
cubic feet is the measure of volume. one cubic foot is 1x1x1 foot. the size of the microwave varies with MAKE and MODEL. but is normally in the range of 1 to 3 cubic feet
Oct 25, 2015 | Microwave Ovens
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
Sep 12, 2014 | General Electric Microwave Ovens
What is the cubic feet on the MW8102SS?
If you can't find any info on the net for this model, measure the cavity. Cubic feet = W X L X H = ??. If I had to, I would guess 1.6 if it is a full size counter top model..
Nov 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Sharp R-1461a. What are dimensions?
The dimensions of your Sharp microwave model number R-1460, R-1461 and R-1462 are 29 3/4" in width 14 3/4" in height and 12 1/2" deep. Capacity is 1.1 cubic feet.
Sep 30, 2013 | Microwave Ovens
No power at all - breaker is on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 07, 2010 | Sharp KB6015 Drawer 24 Inch Wide 1 Cubic...
Everything seems to work but not heat
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
May 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
No light inside of microwave
I hape that's .9 cubic feet, cause it it is 9 cubic feet that is on heckuva microwave!!!. Anyways, did the light once work? or are you curious if it supposed to have a light. If the light once worked, replace the bulb...
Mar 03, 2009 | Emerson Black Microwave Oven
Wattage - Samsung 5380
It looks like it is 900 watts and .9 cubic feet.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 30, 2008 | Microwave Ovens
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Sharp R-510HW Microwave Oven Logo
14 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
