Question about Evga Computers & Internet
Classified SR2 cmos checksum bad - Evga Computers & Internet
    Brigadier General:
  • Evga Master
  • 3,400 Answers
CLEAR CMOS.
Posted on Jan 21, 2015
  • 87 Answers
SOURCE: CMOS Checksum Bad
bios update might fix the problem http://support.asus.com/download/download.aspx?SLanguage=en-us
if da above link doesnt work check dis alternate link but i am sure it'll work
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Asus/Asus-P4P800-SE-Afudos-BIOS-update-tool-226.shtml
Posted on Nov 18, 2007
tom19511
  • 1601 Answers
SOURCE: cmos checksum bad
Here is an explanation of your problem.
http://www.tech-faq.com/cmos-checksum-bad-error.shtml
Posted on Dec 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: CMOS Checksum Bad message
If you have another computer download the previous BIOS update of version 3.0 and see if that works.
Posted on Jul 15, 2008
  • 11 Answers
SOURCE: Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Posted on Jul 27, 2010
ynogami21
  • 670 Answers
SOURCE: cmos checksum bad.chassis intruded fatal
Make sure that the Processor Heatsink is tight. Try replacing the CMOS battery.
Hope this helps!
Posted on Apr 15, 2011
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Mar 05, 2010 | Microsoft Windows XP Professional With...
Cmos checksum error 0251
just replace the "CR2032 battery" in the motherboard... the enter the BIOS, then "LOAD SETUP DEFUALT"
May 18, 2009 | E-Machines T2682 (000002965) PC Desktop
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
Cmos checksum error
cmos checksum errors are caused by a bad battery.
If that dont work then the board is bad from the factory.
Dec 24, 2007 | ASUS A8V-VM Motherboard
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
NO CD-ROM FOUND
Nov 15, 2007 | ASUS M2N-MX Motherboard
Open Questions:
Reset button on EVGA motherboard solid yellow I have an EVGA X58 SLI Motherboard, model 132-BL-E758. My 1200w power supply went out and I had to replace it. I did so with a Corsair 860 hoping it would do the job. I'm running a Radian 7970 video card. I understand it needs a 550w power supply so this should be enough. It may not be. The computer kept shutting down. The Motherboard lights were still on so I presumed the power supply was still working. I checked all my wiring to the Motherboard and may have created a problem. Now, although the fans come on and the Motherboard lights up (green, yellow, and blue lights in the middle of the board) the computer won't start up. The monitor says No Input. I hear nothing to suggest the drives are turning or loading Windows (7). Additionally, and where I hope someone can help is that now my red LED light next to the start switch on the computer case won't come on when I press the start button. Looking inside I see that although all three lights are on (green, blue, yellow) the green power button (next to the yellow reset button and red CMOS button) is not on. Additionally, the yellow reset button is lit up and pressing it doesn't change anything. The question is, is the yellow reset button and green power button on your Motherboard supposed to be lit up, or off? Secondly, with the reset button lit up and the power button off, does that tell you anything? If so, please share that with me. I'm at a loss as to whether I have a possible Motherboard problem, or whether the problem lies in the possibly undersized power supply that I installed, or if I've wired this incorrectly. If all fans come on and the board lights up, does that suggest that the board is fine or could there be a part of the board that isn't working and causing this problem? Because I wired this myself when I installed the new power supply is it possible that I've not installed a wire? Do these symptoms tell you anything that can help me or lead me in the right direction?
Jan 15, 2018 | Evga Computers & Internet
Computers & Internet Logo
103 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
