Question about JVC AV-32820 32" TV
TEAC ct-m685 AV channel???
Just bought a second hand TEAC CT-M685 TV but can't seem to tune in the AV channel. Don't have the remote or the manual. Very frustrating as I bought it specifically for the kids to watch their DVD's on! Anyone figured this one out yet as I know I am not the first to ask. This seems to be a common problem with this make but it shouldn't be as I thought it was quite a good make.
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: jvc av-28gt1sjf
This sounds like a microprocessor controller problem?? Try to reset the tv by unplugging overnight and starting fresh in the am. If it will go in av then your all set BVut if it dosent go into the menu to see if theres any kind of lockout in the set up for the av. If not then youll have to have the set looked at by a pro. Good Luck
Posted on Jun 07, 2006
premtech
  • 934 Answers
SOURCE: JVC Channel Code locked and need to unlock
The square box is not a channel lock it's closed caption and labled CC in your menu.. Go into the menu and set CC off... No more box...
Posted on Jan 27, 2008
ansouk
SOURCE: Help! How can you unlock a pin on a TV that you don't know?
Go to summary of channel and then press your remote control channel down until the check mark beside your channel that is locked is yellow.Press channel down once more so that the lock becomes yellow.Press on the number 0 on your remote and the lock should disappear (mine did)
Posted on Feb 02, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: JVC AV-27CM3
There is no specific "remote code" as such for a TV. A universal remote control will come with a set of codes for you to try, and the control manufacturer makes up these codes. If none of the listed codes work for a particular brand, the remote normally will have a code-search feature so you can hunt for the one you need. If the trouble is that you have a universal remote and no instruction sheet, you can try to find it online, or just buy a new control. They are inexpensive.
Posted on Dec 07, 2008
Teac ct m685 shutting down
Removed and checked the power supply unit and confirmed the capacitors
C905 220uF 420V was measured at 200uF
C926 22uF 160V measured at 21.6 uF
C908 10 uF 100V measured at 10.35 uF
C910 47 uF 63V measured at 45.8 uF
Resoldered all of the joints on this PCB to ensure good connections.
On the Main PCB checked capacitors
C401 220uF 35V measured 214 uF
C417 100uF 160V measured 100 uF
C411 3300uF 35V measured 3090 uF
D204 was still a diode
C430 4.7nF 1600V measured 4.5 nF
C406 4700uF 25V measured 4460 uF
Reassembled and confirmed worked OK
These checks / repairs did fix this fault and the television is running well.
Dec 29, 2012 | Televison & Video
Ineed a power adapter for a M685-E
searching online for "Gateway M685-E power adapter" will result in numerous sources for obtaining one online.
Sep 03, 2012 | Gateway M685-E Notebook
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
Toshiba Remote #CT-847
where can I get the manual for a Toshiba ct-847 remote
Dec 06, 2008 | Toshiba Televison & Video
Set up av on Toshiba CT-871
Must Have been dirty connection tried a second tv it worked when back to the original it worked ???
Nov 15, 2008 | Toshiba Televison & Video
Akai CT-2868AT
I had the same problem with a broken remote for the Akai CT-2868AT which meant I could not access the AV channel. I bought the one-for-all (model URC-7711) universal remote which worked with this model TV.
May 12, 2008 | Televison & Video
TEAC CT-M685
This is a vertical-deflection problem. Try to adjust the vertical (height and linearity and hold) controls, which should be screwdriver potentiometer controls on the back of the set.
If this does not work, a defective component in the vertical-deflection circuit will need to be repaired.
I hope this helped you. :)
Mar 30, 2008 | Televison & Video
Adding a channel to TEAC television
Hi I had the same problem so I bought a cheap universal remote controller and tuned into this model.
Once it is done, press a number on the remote controller and you can start to tune manually.
I do not know about the solution for AV channel.
Feb 14, 2008 | Televison & Video
Toshiba CT-852
A universal remote would cure this problem. It's generally since they are on the same system or IR codes are similar. There isnt much you can do to fix that problem unless you have a seperate universal remote to opperate seperately.
May 05, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
211 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
