Question about Intel Motherboard
Windows i have sata hard drive but not detect in win xp instalation
    President:
  • 2,559 Answers
You need to download the SATA driver for your hard drive to a readable disk and reinstall xp and when the xp installation ask if you need to install 3rd party driver tap F6 and load the driver from the readable disk you put the drivers on,(This cannot be done on the same drive that contains the xp install disk since removing the disk would stop the installation)I recommend a usb drive,But you will need to enable boot from usb device in the bios first.Or if you have a floppy drive That would work too.
Posted on May 19, 2009
  • 63 Answers
Check the drive configuration on the bios.change the present sata configuration to second option it may be both or something like that.
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
We cannot seem to load win XP on DG43NB motherboard with SATA drives. Is there a way to do so?
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Sep 08, 2011 | Intel DG43NB Motherboard
I can't install win xp pro. on my G41MT-S2P..i always get "a disk error has occured" prompt
This model motherboard does not use IDE/PATA hard drives.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive. http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Sep 08, 2011 | Gigabyte Giga Byte Technology Ultra...
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 12, 2011 | HP Compaq 6720s Notebook
Hello my dear i want install 1 hard disk 320 gb and after that install win xp on my qosmio but after start setup win xp show mw did not find hard drive. how can i repair this problem? thanks
In order to be detected the hard disk drive by your windows xp installer. You have to set your sata in your cmos or bios setup. When powering your computer tap the F2 key or Del to enter cmos or bios setup, go to integrated peripherals and look for the sata controllers. Most of the times if its configured as a enhanced the windows xp can not detect it. You have to change the settings to compatible mode. Please the modify key either F5 or F6 or PGUP/PGDOWN or + or - . After changing the settings press F10 and press y and enter. Then try again running the windows setup. Have a nice day.
Feb 17, 2011 | Toshiba Qosmio G35-AV600 Notebook
When I will going to install win xp(sp2) with sata harddisk its show no dsrive installed on your system
Feb 15, 2011 | MSI MBOX K8MM-V Athlon64/Sempron Barebone...
I can't format my HP Compaq 6720s Notebook,win xp say can not hdd drive ,but i'll get new hdd
The reason XP cannot detect the hard drive is because thr hard drive in this model HP is a SATA hard drive and the Windows XP installation CD does not have the SATA controllers on this CD.
To install XP on a SATA hard drive, please click on this link and follow my instructions :-
Feb 03, 2011 | HP Compaq 6720s Notebook
Hi, i am unable to install windows XP in pavilion dv6500 laptop. XP set up is not detecting the hard disk at all can you help me ?
Some copys of windows XP can not detect a SATA hard drive what you need to do is get hold of a later dvd copy of XP only the lastist dvd copys of XP are setup to detect SATA hard drives. It has to be a DVD copy as the CD copys do not detect SATA drives. Find some one with a new computer with SATA drives that has windows XP installed on it and try there copy of XP on your computer. Hopes this helps.
Jan 31, 2009 | HP Pavilion DV6500T Notebook
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
Intel Motherboard Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
