Whirlpool awe 8827 F08 - Washing Machines
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: ho una labiancheria whirlpool awe 9087 come
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Whirlpool washer f08 e02
An F08 E02 error is a dispenser motor error on many Whirlpool washers. This could be due to dried detergent clogging the dispenser. Take the dispenser out and clean it following the directions in your manual. (Add a comment with the model number if you need a link to the manual. Most Whirlpool manuals are available on their support page: http://www.whirlpool.com/manuals/ .)
If that doesn't fix the problem or is only a temporary fix, the dispenser motor/switch may be faulty or the linkage between the motor and the dispenser may be blocked from moving freely. Alternatively the wiring may have a problem with a conductor in the wiring harness. Inside the top panel of the washer is usually a guide for checking the error. (The back panel has to be removed to get to the top panel and this information.)
I hope this helps.
Feb 19, 2015 | Whirlpool Washing Machines
Hello, I have WHIRLPOOL washing mashine model AWE 2214. Yesterday during squeezing, the masine stoped without noise, no indication buttons.I cheked everything, but the mashine no start. Please, help me!...
Go to www.washingmachine-manual.com/whirlpool-awe-2214.html for the handbook. Make a cup of coffee and have a read up. If that fails to help then its an engineer I'm afraid.
If you have a good diy friend have them check the belt drive if it has one? Be careful of electricity and water, they don't mix.
Jul 21, 2014 | Whirlpool Washing Machines
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
Error F08
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Jun 15, 2013 | Whirlpool Duet GHW9150P Front Load Washer
F08 FAULTCODE ON WIRLPOOL WASHING MACHINE WHAT DOES IT MEAN.
Hi.
F08 is heater error. Test heater and wiring to central control unit.
  1. Read impedance and ensure that the heater has continuity.
  2. Check heater contacts for leakage to earth.
  3. Check continuity on the wiring between heater and control board.
  4. Replace either heater, wiring harness or control module.
Jun 07, 2011 | Whirlpool Washing Machines
Reset error code F08 in a whirlpool washing machine, or whats the problem.
May 28, 2011 | Washing Machines
Came up on red service light with fault F08
Dec 07, 2010 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
