Question about Dell PowerEdge 1600SC Server
Beep sound hi my server beep constantly when it boot on
  • AmadouD Apr 04, 2008
    Hello! I have the same problem with the sound , how can i fix it?
  • 4,889 Answers
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology.
A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen..Use registered memory and it will be fine..
Posted on Oct 18, 2007
My Dell Poweredge 1550 won't connect to the screen. It also constantly beeps upon startup
Is it in a 1, 3, 2 beep pattern (beep....beep, beep, beep........beep, beep)? If so, the memory is either not seated well or may be bad. Try reseating your memory. If it continues, try with one stick at a time just to see if it will boot up with a display.
Nov 02, 2013 | Dell PowerEdge Computers & Internet
Dell PE 1800 showed one SCSI 73G non critical state on a RAID 5 array of 3 disks. Shutdown the server, removed the SCSI disk and booted, server booted but continous beep sound, trying to rebuild the array...
Hi, try to renew the drivers and firmware from here:
Continuous beep related to ram ,try to remove ram and insert it, and if u still get beep change your ram.
Continious beeb sound is ram or cpu failure. Is the cpu fan spinning ??
If not the cpu is over heating.
Try to remove the ram modules and clean the contact points
with a piece of paper. Be very carefull when you do that !!!!!
And blow the dust out of your server, with a high pressure can.
Hope this was helpfull.
Mar 28, 2011 | Dell PowerEdge 1800 Server
Will the server boot? (is there anything on the screen?)
If it doesn't boot, it sounds like a memory error.
Remove, and replace the memory to see if it does it again. If it keeps on beeping, then you may have bad RAM. Try with just one module at a time, and see if it will boot.
Jan 28, 2011 | Dell PowerEdge 1800 Server
On power up just get contant beeping won't boot
constant beeping sound is usually a key on the keyboard that is stuck. If it is not constant, like long,short,long beeps, that may indicate a problem. Let me know it is is constant or a beep code.
Nov 23, 2010 | Acer Aspire 5315 Notebook
PowerEdge 1600SC long beep and hang
check the Cmos battery. or levae pluged in over night and then check setup setting you battery went dead
Oct 12, 2009 | Dell PowerEdge 1600SC Server
HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Nov 03, 2008 | HP Compaq ProLiant ML530 Server
Dell Poweredge 700 Server problems
Dear jckim, Which server you are using? Usually this error occurs when raid controller card have some problem.Have you getting any error codes?
Oct 20, 2008 | Dell Computers & Internet
Response to constant beeping on the dell 1600sc server
Please provide me a complete list of components on your server and I will be more than happy to help..
Oct 06, 2008 | Dell PowerEdge 1600SC Server
Constant beep on poweredge 840 appears to work alright
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Apr 02, 2008 | Dell PowerEdge 700 Server
Dell PowerEdge 1600SC Server Logo
912 people viewed this question
Alun Cox
