Question about Bosch Dishwashers
I have a Bosch logixx slimline dishwasher and it ill not drain. Any suggestions? thanks!
    Problem Solver:
  • 9 Answers
Remove filter, drain sump out with cooking syringe to have a closer look you may well have some broken glass stuck between those fins or food stuff. That cover can also be removed with a T10 or T20 (Starhape) screw driver for a thorough search.Hope this helps
Posted on May 19, 2009
Water not emptying
check if the dishwasher is level. designed to drain correctly under level conditions.
Apr 21, 2012 | Bosch Dishwashers
My bosch logixx dishwasher quick wash has never
i would change the control board or control module. thermador .com will let you order it.
Apr 09, 2010 | Bosch SHU9915UC Dishwasher
Blocked drain
try to disconnect the drain hose under the sink and put the machine in drain mode this will **** the water out of thge hose. if the water is blocked in the machine you have to get a torch screwdriver and take of the plastic piece in the center of the unit . that is where the propellor is. then close the door and put the machine into drain. the stuck partical should reverse out.then place cover back on.that should do it
Apr 05, 2010 | Bosch 18 in. SRS55L02 Logixx Slim-Line...
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch logixx slimline dishwasher, the bottom washing jet arm no longer osculates we have cleaned the filters thoroughly and checked the jets but it is still not rotating. Any suggestions at getting it...
does water emerge from the jets if yes than maybe somthing broke such as a propeller that cause dit to spin under water supply pressure?
Mar 13, 2008 | Dishwashers
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
202 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
