Question about 2004 Mustang Factory Wiring Diagrams
Dial string broke for craig IMA radio mode PS1000 radio
Diagram for restring dial cord
How to string a talon garden hawk trimmer
https://www.youtube.com/watch?v=tXUrdUoS_PU
Mar 18, 2015 | Garden
Our string broke on our patio umbrella. is it fixable?
It absolutely is fixable, type restring patio umbrella into your search engine and look at several of the YouTube videos detailing how it can be fixed. The hardest part may be to source the string, why not contact the manufactures and ask if they can supply it. As an additional note you need to make sure all the moving bits work properly and are lubricated not sticking, the string may have broken due to excessive force being needed because all was not as friction free as it should be. http://wwww.dayva.com/contact
Jun 17, 2014 | Dayva 6 Ft Huntington Series Patio...
How to restring cub cadet 173cc push mower
take off the hood remove any old string, now wind up the spring and hold it tight put the new string through the hole in the hood and into the hole in the crank wheel pull it through 6 or 8 in. slowly let the spring unwind now tie a knot in the rope and you're done
Sep 15, 2013 | Mtd 19 In. 173 CC OHV 3-In-1
The string broke. It is a yard machine lawn mower
Take pull string housing off. Looks like 3 or 4 screws. Should be able to restring from under side. Either buy new string or if old string is long enough, just tie knot on the end. Good luck
Feb 03, 2013 | Garden
The string that controls the volume pot has broken
Replace the string. Possible sources are "dial cord" used in older radios to move the dial pointer... Find it online.
Another source might be braided fishing line.
Aug 31, 2010 | Ernie Ball 6166 Mono Volume Pedal
I have a Saalburg 5380 C 1964 radio. The tuning dial does not work. When i open the back and have a look it apears that the shaft from the tuning dial which controls the tuning capacitor(Trimmer) must be...
Hi
So you have a slipping dial pointer/tuner drive on your vintage radio. It will be old age catching up with it for sure:) The shaft may have dried grease in its bushings seizing slightly, or more likely, the dial drive cord has lost its "grip". They do stretch over the years. I recall as an apprentice having to do every faulty dial cord that came into the workshop, until we got a new apprentice that is :)
Best bet, BEFORE YOU START doing anything, even if the cord is broken, make a hand drawn diagram of exactly how the cord runs. You may be able to find one that matches up to your radio here, Short of that(as well as), take closeup photos from several angles.
Once you are confident you have an understandable diagram of how it is strung, you can proceed to mess with it.
I have to be honest, completely replacing the cord is what I found to be the quickest/most reliable way to repair them, but then I had plenty of practice in the end. If you don't have the correct type of dial cord string, then repairs can be a fiddly, but effective option to attempt.
First you need to determine if the cord is failing/stretched, or if there is a stiff bearing point. This takes a bit of hands on approach to determine. put some additional tension into the cord by pressing down on it and see if the drive improves. If it does, then you may be able to apply more tension into the drive by shortening it a little. Do this by carefully unhooking one of the retaining springs that secure an end, without removing the chord from the spring, retie the another loop knot(as many as you need to before there is no more room to do so) onto the spring to use up some cord shortening it. Apply a dab of nail varnish to any knot once secure to be sure that it does not come undone. You can just cut the knot away and retie if you wish also, just fiddly with the limited amount of string you have to work with. It often does not take much to re-tension it. Sometimes it may be as easy as fitting the spring to another tighter hook point on the large pulley(if you are lucky) This can be about the time when you are thankful you made a diagram of the way the cord is strung,as things can get messy.
If it appears that the tuning gang is seized, then a drop of penetrating oil to the bush will help it. Work it back and forwards a little to work the oil in. The large pulley attached to the tuning gang can be removed here also if you wish to work on the gang. use some tape to secure the string in place to the pulley and it can generally be removed from the gang and secured back onto the chassis somewhere, whilst keeping tension on the string. Check also the free running of any brass pulleys along the drive. It is imperative that you don't get any oil onto the cord itself or the drive surfaces of the pulleys. ... or you will need to replace the whole thing. A syringe is the best applicator of oil for these jobs. Lubricate sparingly and as a last resort only.
Worst case, you may need to completely restring the drive anyways. I did suggest that at the start.
Good luck with your dial drive repair. If you need new cord, it can be purchased from a vintage radio restorer online or just take it to a vintage repair shop in someones back shed in your neighborhood :)
regards
robotek
Nov 05, 2008 | Audio Players & Recorders
2004 Mustang Factory Wiring Diagrams Logo
26 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
