Question about 5103L Security/Remote Start System
Both my remotes to my avital remote start quit working when i tried to open trunk with my car cranked.
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
ltfrc
  • 227 Answers
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
logosc75
  • 625 Answers
SOURCE: i have a problem with
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Posted on Feb 25, 2011
logosc75
  • 625 Answers
SOURCE: I bought a used car
The Camry you purchased may not be equipped with a power trunk. Press and hold the trunk button for appoximately 4 seconds. The trunk should release if the wire is connected and, you have a power trunk.
The Camry (and other toyotas) require a double pulse on the unlock wire. If the double pulse is not programmed the aftermarket unit will mimic the factory keyless entry. One press of the unlock button opens the drivers door. Immediately press the unlock button again to unlock the other doors.
Posted on May 06, 2011
HOW TO OPEN TRUNK WITH AVITAL KEYLESS REMOTE
all depending if your trunk work with negative ,or positive pulse if it is positive you have to used a 5 pin relay and if its negative just connect it straight
May 17, 2015 | 5303L 2Way LCD Remote Start Security...
I had a avital remote start pot on a 2004 chevy venture van. everything worked ok for a month then the remote locks, poer windows and dome lights quit working. are they all connected together for the...
Avital is one brand of remote starter that features easy-to-use keyless remotes. These remotes can be programmed wirelessly to your engine and then added to your keychain. Once programmed, you will be able to use the remote from as far as a couple hundred feet away in your house, the street or a parking lot. If your remote is not working, you can troubleshoot the remote and get it resynced in seconds.
  • Enter your caricon1.png, leave your driver's door open and insert your key into the ignition.
  • 2 Turn the ignition to the "On" position and press and release the "Valet" button on your remote.
  • Press and hold the "Valet" switch again after releasing the first time and wait for the system's siren to chirp and the LED lighticon1.png to blink.
  • 4 Continue holding the "Valet" button and then press the starter button on your remote.
  • 5 Wait for another chirp and release both buttons to complete the process.
  • Apr 08, 2014 | Cars & Trucks
    Avital 5303 kills engine while driving 1998 honda civic
    you check to see if the engine was hot or something like if the water level in the radiator was down the sensors in the security system would pick it up
    Jan 27, 2014 | 5303L 2Way LCD Remote Start Security...
    Tach and speedo quit working after remote start installed. My 04 yukon's speedo and tach will quit working. I can unplug battery for 5 minutes and will work for a few days. If I turn off vehical o
    Well, if you connected the tach sense wire (violet/white) from the Avital, remove it and use either virtual tach or voltage. It sounds to me that whatever you have connected to the tachometer is sending a signal rather than sensing, causing the malfunction.
    Jan 20, 2013 | 4103LX Remote Start System with Two...
    I bought a used car toyota camry 2005 and it has avital key less remote system installed. model is 474L. It has remote start working and drive door open/close However, i am not able to open the power...
    May 05, 2011 | 474L TX 4-Button Replacement TX Remote
    How do i reset my remote start car alarm avital 5303
    i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
    Feb 21, 2011 | 5303L Security/Remote Start System
    Cranks but engine doesn't start avital remote start
    Jan 28, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
    Engine cranks will start fine with key remote will not start it
    5103L Security/Remote Start System Logo
    19 people viewed this question
    Top Avital Vehicle Parts & Accessories Experts
    D. E. Hev
    Colin Stickland
    Colin Stickland
    Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
