Question about Powermatic 1352001 3520B 20x35" Wood Turning Lathe
I hav a Powermatic model E16 planer, the motor has been changed to 1 phase 220 amp , the speed sees too slow, what speed should the cutters turn
    Genius:
  • 1,406 Answers
If it's got the 3-3/4" three-knife cutterhead, it should run pretty near to 5000 RPM. If it's got the 1-7/8" two-knife cutterhead, it should run at nearly 10,000 RPM.
That planer should take a 3600 (3450) RPM motor.
Posted on Jul 29, 2014
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
Planer will not get up to speed
I suspect that the works are clogged up with wood chips or some long fibers like hair or string. You will have to do enough disassembly so that you can pull out the chips that are wrapped around the shafts, without removing the blades or any of the shafts themselves. The motor, the cutter, and the feed rollers could all be clogged up - as well as the speed reducing mechanism that makes the feed rollers turn slowly. Using compressed air will not do the trick. Needle-nosed pliers and a nut-pick will probably do it. Hair can be hard to see - so be thorough in cleaning. Good luck.
Dec 20, 2012 | Craftsman 12 amp 12-1/2" Bench Planer...
How do you change the cutter bar bearings on a delta 12 inch planer
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
Sep 03, 2012 | Delta Masonry Tools
Jointer doesn't run smoothly
My bet is that the motor is designed for 220/240 (single or three phase), but you're running in on 110 single phase. If the belt were slipping it would sound like the belt on a car (you know when someone starts their car and belt is loose and goes "Sccrreeeeeee" until the rev the engine and make the belt catch up to the pully).
The power in wood working motors is such that it should be very difficult to slow down the motor if you're feeding at a slow rate. But, if the motor needs 220 and you're powering with 110, then the motor will have no power (the magnets in the motor are matched with the voltage - and if you have the wrong voltage you won't get any power and the speed will be very slow).
Typically the "home" or "residential" tools only run on 110, but if you have a larger unit they can be wired for 220 or 110. If you bought the planer used, they may have been running with 220 and now you're powering with 110 (or vice versa). I'd do a quick google search for your unit to see what it's capable of. Or, just take the model number of the motor (not the planer) and search for that.
Typically, motors can be run at 110 or 220 for larger wood working tools. Inside the metal housing where the wire feeds into are a number of wires to connect to. These wires have numbers on them (either a tag or printed on the wire insulation) and you attach them a certain way for 110 and a different way for 220. Sometimes you can even change the direction of the motor - SO BE CAREFULL IF YOU REWIRE IT! don't power it up all the way on the first try. Just start it and then stop it while the motor is still coming up to speed. While the planer is still spinning (even though the motor is off) feed your board in slowly and you'll be able to tell which way the motor is spinning. If you get the wrong direction on your motor you can shoot boards across the shop (or out into the street if you're in the garage - like I did).
Jun 23, 2012 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Single phase motor 220 convert to110v; do you have switch wire inside the motor
There should be a label showing the change, one wire gets switched over to a different screw, all motors are different, but all basically the same, some will not switch. It would be just as easy to run a new line to your motor and it will be right, single circuit, 220 volt,?amp, no worries., Your motor as is will not run in 110 volt mode at all. Hope this helps.
Feb 26, 2012 | Delta Table Saw Tool Base 50279 Band Saw...
I have a wood planer with a 3HP 220 single phase motor wired to 20amp circuit breaker in my house. I usually run the planer off a 12gauge extention wire about 30ft from the house plug. I would like to...
Look on the planer to see what the R.L.A. are, for example 16.0 amps. Set a box with 2- 20 amp fuses, or a double pole 20 amp breaker. Do not exceed the amperage of what the planer says on its data plate. If the R.L.A. is 10.0 to 19.3, use a 20 amp.
Sincerely,
Shastalaker7
Jan 20, 2011 | Inline 20 amp. In-Line Circuit Breaker
I want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
Nov 25, 2009 | Powermatic 1791297/Model 209 5HP 3Ph 230V...
Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Sep 07, 2009 | Powermatic 1791210 Model 15S Deluxe Planer
I have a Powermatic 66 that trips breaker
Either it has a problem with a blade brake or the motor is siezing. Or the is a wiring problem. With the unit unplugged check and see if you can turn the blade by hand, if not the motor is the problem. If it does you could still have a motor problem by it drawing to much amperage or the is a wiring problem.
Aug 31, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Powermatic 1352001 3520B 20x35" Wood Turning Lathe Logo
155 people viewed this question
Top Powermatic Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Powermatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
