Question about Polar F4 Heart Rate Monitor Watch
Polar m62 watch strap
Need to replace watch strap
4 Suggested Answers
SOURCE: how to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Posted on Nov 28, 2009
Coachphil
  • 347 Answers
SOURCE: Polar ft60 showing only 00
There is a problem with your watch. Send it back to Polar it should still be under warranty.
here is the contact information for sending in.
Posted on Jan 24, 2011
Coachphil
  • 347 Answers
SOURCE: Where can I find a
You can get these directly from Polar. www.polarusa.com or www.polar.fi
Posted on Apr 06, 2011
How do i get a polar f7 watch band replaced the watch is just over 2 years old
You can get replacement band on amazon, click here and take a look Amazon com polar band replacement. I hope this was helpful, have a nice day
Feb 03, 2012 | Polar Electro POLAR FT40 Heartrate Monitor...
Where can I find a new watch strap for my Polar AXN 500
Apr 05, 2011 | Polar AXN 500 Watch
Can you change the battery in the chest strap for polar f6
There are two types of straps for Polar:
1) hard rubber/ solid - These can not have the battery changed.
2) soft strap with connector in middle - these you can change the battery.
If you have the soft strap, it will have a small hard around 3 inch long block that "snaps" onto the strap to connect it. These have a battery compartment. Turn it around and you will see the outline for the battery compartment. These are not always easy to open, and the batteries are a little harder to find. Take it into any watch repair and they should be able to pop a new battery in for you pretty easy.
There is a link on my tips and tricks page to get manuals for Polar products, the T-31 wearlink is the product we are talking about, it has the how to change the battery and battery type.
Jan 12, 2011 | Polar F6 Wrist Watch
Reset button has no impact on S120 - no functions available other than time of day
The S120 is now a fairly old watch. When the function buttons and heart rate cease to function this is generally an indicator that the battery needs to be replaced. The buttons themselves can also become worn out or weak of function, in either case you have a couple of options.
1) send in to a Polar Authorized Service center: This is very important, do not take to a normal watch shop. You need the watch properly resealed and handled correctly as well as you may need parts such as a button return spring they will not have. Plus there is a 90day warranty on Polar's repair. You will also need to send in your chest strap just to make sure that is still functioning properly. Battery repair about $15-, new buttons another $10ish, and a chest strap if needs replacing about $25 or $30-. $50-$60 total if everything needs work, but this is just an estimate.
2) buy a new watch unit. The RS100 (the current replacement) is about $100- and is easier to use with a better chest strap.
Dec 28, 2010 | Polar S120 Wrist Watch
Changed the battery and now it won't pick up the heart rate monitor. I know the monitor works because it is picked up by all the equipment in the gym.
If Heart Rate is being displayed on the equipment in the gym, but not your watch, then your chest strap is transmitting fine, but the watch is not recieving the signal.
It is not uncommon that when a battery is changed outside of a polar authorized service center that something can happen to the internal electronics. I would suggest you send the watch into Polar and have them take a look. if you have had the watch less than 2 years they will most likely take it under warranty and correct the issue, at the very least they have equipment to test and diagnose both the watch and strap, although it sounds like your HR strap is fine since you are getting HR on the machines.
Dec 27, 2010 | Polar FT40 Heart Rate Monitor Watch
I have no speed or trip distance showing, cadence is normally ok. also my watch strap has broken and because it is glued on i cant get it fixed!
Since your Cadence is working then there is a problem with the actual speed/ distance sensor. First make sure that in your settings you have speed turned on. If so then...
1) Your battery may be dead = Replace CS sensor
2) The distance of the sensor and magnet is not set correctly = make sure magnet on spokes and sensor are within 1-2mm of each other.
Polar can fix the strap, you need to send into an authorized service center. They replace the entire strap unit. If you send into Polar to get the strap fixed, then you can send in the sensor unit as well for diagnosis if you want. But if #2 doesn't fix, then it's #1 and they will just tell you to buy a new one anyway.
Nov 29, 2010 | Polar CS300 Cycling Computer and Heart...
How to replace battery in polar f4 watch
Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
Polar CE0537
you need CR2032 lithium batteries. They can be found on amazon (pretty cheap). here Finally charging for our multi device world
click on the link and chose some (by price or vendor...) I hope this was helpful. cheers
Aug 20, 2009 | Polar A5 Wrist Watch
Polar F4 Heart Rate Monitor Watch Logo
66 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
