Question about LG LDS4821WW 24 in. Built-in Dishwasher
Lg dishwasher 3850dd3006a does not turn on
Will not turn on or show power is but outlet is good
MNTECH
  • 1543 Answers
SOURCE: Dishwasher
If you have confirmed power to dishwasher, you are pobably looking at a control board. I have only run into this one time on a LDS5811 so far. Parts on LG dishwashers have a two year warranty. You have to dissassemble the door to replace the part.
Posted on Aug 27, 2008
omaharox
  • 166 Answers
SOURCE: LG Dishwasher (3850DD3006A) is leaking along left
Contact LG @ 1800 243-0000 this is a known issue and they may help you out.
The drying vent needs to be updated if this is a couple years old amoung other items such as the wire harness and inner door liner..
Posted on Jan 09, 2010
heatman101
  • 43501 Answers
SOURCE: lg dishwasher 3850DD3006A smells like an
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 05, 2010
heatman101
  • 43501 Answers
SOURCE: LG Dishwasher 3850DD3006A. The
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Posted on Oct 27, 2010
Daniel S
  • 4323 Answers
SOURCE: LG dishwasher mode# 3850dd3006a is
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Posted on May 08, 2011
LG Stainless. P/no 3850DD3006A Model number tag is missing, what model is this? Also, error code E1, what does this mean? Thanks!
The E1 error or fault code indicates that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
Nov 06, 2015 | LG Dishwashers
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Lg p/no 3850dd3006a leaks at door
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a sheet of paper and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced
Jun 19, 2014 | LG Dishwashers
LG dishwasher mode# 3850dd3006a is not draining water.
Hi
Daniel
May 07, 2011 | LG Dishwashers
Dishwasher makes a buzzing noise and then shuts itself off.
MINE IS A 3850DD3006A AND IS 4 YEARS OLD. I HAVE CHANGE THE MOTOR TWICE FOR THE SAME PROBLEM, IT GIVES CODE LE. THE MOTOR RING SPLITS AND WON'T LET THE MOTOR SPIN EASILY.
WHAT A PEACE OF JUNK!!
Nov 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
Cant take out the motor
MINE IS A 3850DD3006A AND THE MOTOR IS HELD IN BY THE PROPRLLER IN THE TOP. AND UNDER NEATH THE MOTOR BY SCREWS.
Nov 25, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Lg dishwasher 3850DD3006A smells like an electrical short when running
heatman101
Aug 05, 2010 | LG Dishwashers
I just installed the dishwasher and do not turn on
On the LG LDF6810 model, you should be able to open the door and press the power button (right side of the top of the door.) It should wake up and you should see lights.
If that fails to happen, trace the power from under the dishwasher to where it is plugged in to the wall. If it is under the sink and you have a waste disposal, it is very possible that both outlets are switched on/off by the disposal switch. I would find a known-good table light or something similar and plug it in to the outlet and see if the light turns on when I switch it on. Electrician is needed to separate the top/bottom outlets so the dishwasher is always on and the disposal is properly switched.
If the dishwasher is not connected to an outlet, rather directly connected via electrical wire, have an electrician confirm the hot, neutral and ground wires are properly connected under the dishwasher and check the circuit breaker/fuse for that circuit.
Please report back what you find, OK?
May 20, 2010 | LG LDF6810ST Stainless Steel Built-in...
My LG dishwasher (LDF7810WW) makes a whining noise when the motor starts up. It continues on and off when it is running. Is the motor bad?
MINE IS A LG 3850DD3006A AND YES THE GARBAGE DISPOSER GETS STRAWS AND JUNK IN IT. OR THE SCREEN ON THE TOP IS COVERED WITH MACARONI AND CHEESE. OR TWICE IN 4 YEARS THE MOTOR RING SPLIT AND THE MOTOR STARTED TO GRIND THAT RING TILL IT STOPPED ALLTOGETHER.
I ADMIT THE STRAWS ARE THE USERS FALT!
Apr 24, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Jan 07, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDS4821WW 24 in. Built-in Dishwasher Logo
18 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
