Question about Korg PA588 88-Key Professional Arranger Combo Piano Bundle
My korg pa 588 says OS not present - Korg PA588 88-Key Professional Arranger Combo Piano Bundle
Problem with Korg PA-50 joystick in Program mode
Most likely the Program Mode does not copy joystick info.
Get the User Manual online, if you want Google
KORG PA50 FACTORY RESET
But then you will lose all your memories...
Dec 02, 2017 | Korg Music
Halo my name is budi..i am an indonesian korg pa50 user ..my pa 50 was blank and only rised on display "ssd not present"..what should i do??
Hi
I work with computers rather than musical instruments, but I imagine with all the things keyboards do these days they are almost certainly computerised, and your saying "tried to install os" confirms this.
In computers "SSD" stands for "Solid State Drive". If there is an SSD in the PA50, then it is quite clear to me that it is no longer working properly and needs to be replaced. Confirmed by the fact that you can't install the OS.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Korg Music
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
Mar 28, 2014 | Korg Pa800 Synthesizer
Kord pa 50 enciende, pero no funciona
ola claudio
tienes que resetear el organo y despues cargar el os
Dec 13, 2013 | Korg Pa50 Professional Arranger Keyboard...
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
Hw to cancelvirus in pa 800?
Do a factory reset. Look in your book or search for: "Factory reset pa 800" with google.
Sep 18, 2009 | Korg Pa800 Synthesizer
Korg PA588 88-Key Professional Arranger Combo Piano Bundle Logo
32 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Are you a Korg Music Expert? Answer questions, earn points and help others
