Question about Hypertherm Powermax 30 120-230V 1-Ph Deluxe Manual Plasma Cutter W/ Case & Accessories
My powermax 30 plasma cutter willnot start up
No temp light no spark at gun head
I have Hypertherm Powermax 600 and the green OK light does not come on at times. I will let it set over night and it may come on or maybe not. Driving me NUTS!!! Please can you help. Thanks
you might have a bad relay on your circuit board. They arc and spot weld themselves at times (nothing a sharp hit can't fix) Replace the relay with a higher quality one if you can.
Oct 30, 2013 | Welding Tools
My Thermal Dynamic Drag Gun Plasma Cutter runs but cant blow its arc. Bit of spark, Bit of air, then just refuses to blow its arc. Was working well and with new tips and electrodes but then just refused....
Hi:
There is no mention of the Thermal Dynamic's gun model, but i will suppose that it is a SL60 or a SL100 which are replacement guns for any model of plasma using the proper adaptor.
Your problem could be the start cartridge which go bad now and then when the gun is used as a replacement of a hammer to make the cut piece to fall.
The way to check if your start cartridge is in good condition is by checking the low part of the cartridge, push it up (or down depending on the way you handle it) it should freely slide inside and return out.
Good luck.
Jun 16, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
When air is hooked up it blows the air regulator and all the air blows out valve very little gets to gun.red safety light comes on on front of machine and it will not work
Air pressure should be no more than 90#s. If regulator cannot handle at least 125#s . Get a new regulater. Sounds like this regulator has a blown diaphram.
Nov 11, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
The lights are working for power and gas pressure but not the DC arc....BIG Repair problem?????? It a Pak Master 25 Plasma cutter from Thermal Dynamics bought 15 years ago
No, Try changing the tip. The one under thr node cone. If it burns back it will concave and increase the gap between the work and gun tungdten electrode.
Oct 30, 2009 | Welding Tools
If you have a old plasma cutter can you swap ot
yes it does matter.each brand is set up for their own torches.
Jul 02, 2009 | Welding Tools
My SIP 30 is not working. It has a normal air pressure light, normal air flow at torch. The torch has all new consumable parts but no spark when activated. Inside the voltages at the torch leads are about...
It has become my experience that the trouble is in the torch head, especially after the torch head has gotten hot during use. Replacing it may solve your problem.
Apr 07, 2009 | Welding Tools
Need to switch 3 phase to single phase
An electrician can provide you with a TRANSFORMER that has a single phase primary and 3-phase secondary. The secondary would connect to your Plasma Cutter. He may be able to find you a used one. Ask him what you need for the size of your Cutter, and you may be able to find it on Ebay.
Mar 26, 2009 | Welding Tools
Miller 2050 that will not spark.
This is relative to 3 causes , contol board , pwm board or torch
Feb 28, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Hypertherm Powermax 30 120-230V 1-Ph Deluxe Manual Plasma Cutter W/ Case & Accessories Logo
104 people viewed this question
Top Hypertherm Welding Tools Experts
Bill Boyd
Are you a Hypertherm Welding Tool Expert? Answer questions, earn points and help others
