Question about Bose Cinemate Digital Home Theater System Speaker
What is yellow light means in bose module - Bose Cinemate Digital Home Theater System Speaker
Red light on not green
helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Sep 01, 2014 | Bose Solo TV sound system - Black
How to hook up bose b1 module into yamaha emx 5000
The Bose B1 bass module is designed to handle up to 125 watts into 8 ohms 40-200 Hz.
The Yamaha EMX 5000 is full 500 watts, and full range. This is not a particularly good match.
EMX5000 Powered Mixers Mixers Live Sound Products Yamaha United States B1 Bass Module Bose L1 Encyclopedia FAQ Wiki
Apr 29, 2014 | Bose Audio Players & Recorders
My bose solo has a yellow light instead of green
The yellow light means you are in reduced bass mode. Hold the mute button on the remote for about 3 seconds and you'll hear 3 tones going up and the light will switch back to green. Enjoy!
Mar 01, 2014 | Bose Solo TV sound system - Black
Bose L1 no volume
If the power light turns and stays yellow, there is nothing you can do to fix it. You'll need to talk to Bose L1® Support
Call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
Monday-Friday: 8:30 AM - 9:00 PM ET
Saturday 9:00 AM - 5:00 PM ET
Or write to them at the Bose Forum
Ask Bose for Help Forum
Jul 28, 2013 | Bose L1 Speaker
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
May 17, 2011 | Bose Acoustimass 15 System
I have a Bose sound system companion series 3 ii and the lights just yellow and no sounds coming out and it turned red and no sound was still coming out.It was working fine about half a an hour ago
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
Dec 25, 2010 | Bose Companion 3 Computer Speakers
Same problem. Bose CineMate light went red and doesn't come back green even if I tried changing batteries and doing 5 step approach mentioned above.
If resetting this system and re-seating the interface (box with light) to the bass module doesn't fix this, you may need a new interface module. This sells for about $40-50 from Bose. If this is under it's 1-yr warranty, they should be able to replace this for free.
So just incase you haven't tried it: 1. Unplug the power cord from the bass module (sub-woofer) along with the interface module and wait at least 30+ seconds. 2. Re-connect the interface first- screw it in as tight as can be. 3. Re-connect the power cord, and try the remote again.
This is really the only solution, and it's exactly what their tech support will have you try. That's the one functionally weak point with that system, that little module needs to be adjusted and re-seated from time to time.
Jun 15, 2009 | Bose Cinemate Digital Home Theater System...
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
Hooking tv to Bose radio
You need a pair of RCA cables.You might have some extra.First if you have a cable box or satellite box you must use a pair of rca's (3 cables, yellow, red, and white ends).If you have a digital cable or satellite box the on the back there will be rca outputs.use one of the rca cables and plug it into the output of the cable box to the INPUT of the Bose stereo(they will be labled) then on the OUTPUT of the Bose take another pair of RCA cables and plug them into the rca INPUTS on the TV then use the original remote to the TV and change the Input source the either AUX 1 or AUX 2 which ever aux you pluggen the cable into coming from the output on the Bose.If you do not have a digital Cable or Satellite box then you will need a Modulator.What this is ,is a small box that will convert the regular cable coming from the wall into those RVA cables that would plug into the INPUT of your Bose. you can get a modulator from walmart meijer radioshack...ect for about $20.Hope this helps,rate me if it does or leave more info.GOOD LUCK.
Nov 18, 2007 | Bose Wave Radio
Bose Cinemate Digital Home Theater System Speaker Logo
29 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
