Question about Bose Cinemate Digital Home Theater System Speaker
What does it mean if bose cinemate module has red and yellow lights on
SOURCE: Bose Cinemate Home Theater
same prob, the tech was no help wants me to send in 75 bucks and pay for the shipping
Posted on Apr 28, 2008
SOURCE: cinemate bose home theatre system
called bose they said to unplug the actual reciever piece from the back of the sub and to wait 60sec and plug back in and turn on. they also said that sometimes a surge protector can cause the remote to foul up
Posted on Jul 16, 2008
  • 19 Answers
SOURCE: remote control codes for a Bose Cinemate
I would contact ur nearest Bose dealer or Contact the company through the website to get a replacement remote, you will of course need the serial number for the product when you contact them, using a universal remote can make things easier but you will not be able to access most of the functions without the original
Posted on Apr 03, 2009
  • 7 Answers
SOURCE: Connecting my HDTV to my Bose Cinemate
If your BOSE system only has one audio input you will have to connect everything to your tv and like the other guy said there will be an audio out on the back of your tv, connect that to your BOSE and when you switch inputs on your tv it should send that audio to your speaker setup.
Posted on Apr 06, 2009
SOURCE: code for Bose cinemate surround system
We just got a Bose Cinemate system and have the same issue - none of the listed codes for the Synergy V work.
Has anybody got this to work yet?
Posted on May 23, 2010
BOSE CINEMATE WILL NOT TURN ON
pretty commong problem with these unit is for the control box to go bad. If it's not under warranty, i suggest contacting Bose for service as they usually will give you a flat-rate repair no matter what is wrong with your unit.
Aug 02, 2014 | Bose Cinemate Digital Home Theater System...
The light on the interface will not come on
Try powering the unit down for 30 seconds and then power it back up.If after pluging and unpluging you still have the fix red led then the IR Detector Module inside the CineMate Interface Module is not working. You have to replace it. The Part Number is 1B83 41A. You can but this part at Radio shack for under $5.00 , remove the old one and solder a new one in, 3 leads of the LED. This was the way I fixed mine
Mar 23, 2014 | Bose Cinemate Digital Home Theater System...
Bose cinemate troubleshooting
If the light on your control console just stays red and never changes, then the control module is probably bad. It's pretty common on the cinemate models.
Jun 06, 2013 | Audio Players & Recorders
Replacement part for Bose Cinemate Interface
Replacement parts for Bose Cinemate Interface can be foudn at amazon, take a look here: Amazon com Bose Cinemate parts. I hope this helped. Cheers
Oct 29, 2011 | Bose Cinemate Digital Home Theater System...
When I plug in my cinemate system the green light on the interface module won't turn on and power up. It only stays red and doesn't respond to the remote. I have unplugged and reset the system and check...
probablemente no este ccodificado el control remoto asegurate de poner pilas nuevas y trata otra vez checa los cables que van al modulo interfaz ya que pueden estar quebrados o sustituyelos o bien el sistema de interfaz no funciona o llevalo al centro de reparacion bose
Apr 21, 2010 | Bose Cinemate Digital Home Theater System...
Same problem. Bose CineMate light went red and doesn't come back green even if I tried changing batteries and doing 5 step approach mentioned above.
If resetting this system and re-seating the interface (box with light) to the bass module doesn't fix this, you may need a new interface module. This sells for about $40-50 from Bose. If this is under it's 1-yr warranty, they should be able to replace this for free.
So just incase you haven't tried it: 1. Unplug the power cord from the bass module (sub-woofer) along with the interface module and wait at least 30+ seconds. 2. Re-connect the interface first- screw it in as tight as can be. 3. Re-connect the power cord, and try the remote again.
This is really the only solution, and it's exactly what their tech support will have you try. That's the one functionally weak point with that system, that little module needs to be adjusted and re-seated from time to time.
Jun 15, 2009 | Bose Cinemate Digital Home Theater System...
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
Bose cinemate will not power on. light stays red?
Make sure your system is not plugged into a surge protector. Sometimes a surge protector will foul the system up, don't know why. lol. I fought with my system for 3 hours trying to get it to work, then moved it from my surge protector to the wall and it came on. If that doesn't work, try disconnecting the receiver module itself, wait 60 sec, then plug it back in. If that still does not solve the problem, I would suggest calling Bose Customer Service..
Jan 25, 2009 | Bose Cinemate Digital Home Theater System...
Bose Cinemate home theatre
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
Jan 09, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
