Question about Cycling
Edge 595r up down buttons dont work - Cycling
2 Suggested Answers
valeantudor
  • 787 Answers
SOURCE: I have not used my
Unfortunately, there is no procedure you can use in order to clear the E1 error. The manufacturer recommends contacting their technical support in order to have this problem fixed but you should expect them to send you a new bike.
Posted on Jan 30, 2011
Need part for Edge 595r recumbent bike, can you supply it?
sorry but no we can not . try a bike shop
Feb 08, 2016 | Cycling
Have a Leica Disto basic and need to know how to change measurement from m to ft.
Press and hold the circle button down, after a few seconds it will flash 'beep on/off', dont stop holding it down, it will then cycle to 'units', press +/- to change between metric and imperial, then press the = button to store. If you keep holding it down you can set the reference pont (where the measurement is taken from, the back, middle or front edge of the machine) add an offset (add take away from the displayed dimension), and you can also reset the machine.
May 20, 2011 | Leica DISTO A5 Rangefinder
Where is laptop power button in hp mini laptop?
power button is on the right side of the netbook its a small sliding switch
Mar 15, 2011 | HP Mini 1000 Netbook
Used my garmin edge 305 today on the ride, it worked fine, powered off after the ride. Got home turned on to review my stats and then powered off and went to upload and wouldn't upload, so tried to turn it...
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Jan 30, 2011 | Garmin Edge 305 GPS Receiver
Garmin edge 705 will not turn on
Nov 08, 2010 | Garmin Edge 705 Handheld GPS Receiver
Front driver side window problem in ford edge
try this, it may or may not work. Using the window button, put the window down and continue to hold the down switch while you count to 10. Release the button. Next put the window up with the window button and continue to hold the button in the up position while you count to ten again. Then put the window down and hold the button and count to ten again. The window operates on current draw to know when it is closed. This should retrain the window to know its open and closed limits.
But once again this may not work but it is worth a try. Hope this helps.
Apr 03, 2010 | 2008 Ford Edge
I have a Watchguard Firebox x10e and i can not log into it
To recover your Firebox X Edge e-Series device, you must first reset the Edge to its factory default settings, and then FTP the Edge v10.x appliance software to the Edge.
To set the Firebox X Edge e-Series to the factory default settings:
  1. Disconnect the power supply.
  2. Hold down the Reset button on the rear side of the Edge.
  3. Connect the power supply while you continue to hold down the Reset button.
  4. Continue to hold down the button until the yellow Attn light stays on. This shows you that the Edge was successfully restored to the factory default settings.
    This process can take 45 seconds or more.
To FTP the Edge v10.x appliance software to the Edge:
  1. Copy the Edge v10 upgrade file (yakfw.sysa-dl) to the root of your C: drive.
  2. Edit the network settings on your computer so that it is part of the 192.168.111.0/24 subnet.
  3. Connect your computer to any of the LAN interfaces on the Edge.
  4. Open a command prompt.
    To open a command prompt, select Start > Run. Type cmd and press Enter.
  5. Type ftp 192.168.111.1 and press Enter. When prompted, enter the user name admin and the password admin. Press Enter.
  6. Type bin. Press Enter.
  7. Type put yakfw.sysa-dl. Press Enter.
  8. Type bye. Press Enter.
  9. Type exit. Press Enter.
    The command prompt window closes.
  10. Power cycle the Edge.
Oct 01, 2009 | WatchGuard Technologies WatchGuard Firebox...
Touch buttons dont always work on a dd603 dishwasher
Hi and welcome to FixYa!
If you are talking about the cycle selector buttons up on the top edge of the drawer, I can help you with this. When the selector button gets wet or has moisture buildup or soap residue, it will not sense the touch from your fingertip. It is not a mechanical button per se. If you take a clean dry cloth and wipe the recessed area where your fingertip touches the button, it will respond 100% better than it will when it is dirty or just plain wet. I show my customers this practically every day.
The only other thing that will cause this is the tab behind the control panel sometimes cracks and will not hold the computer tightly against the underside of the drawer edge. This is rare though. Clean the surface of the drawer edge and it will change cycles again like new.
Dec 11, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
How to Factory reset Firebox X20e edge
  2. Hold down the Reset button on the back of the Edge.
  3. Continue to hold down the Reset button, and connect the power supply.
  4. Hold down the Reset button. When the yellow Attn light stays lit, the Edge was successfully restored to the factory default settings.
  5. Release the Reset button.
Do not try to connect to the Edge at this time. Before you can connect to the Edge, you must start it one more time. If you do not, when you try to connect to the Edge a web page appears with this message: Your WatchGuard Firebox X Edge is running from a backup copy of firmware. You could also see this message if the Reset button is stuck in the depressed position. If you continue to see this page, check the Reset button, and start the Edge again.
  2. Connect the power supply again.
    The Power Indicator lights and your Edge is reset.
Sep 02, 2008 | Computers & Internet
Cycling Logo
23 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
