Question about Toshiba 42HL196 42 in. LCD HDTV
Color is heavy on the green. Can't adjust it to look normal.
The color has suddenly gone heavy on the green and we can't manage to adjust it back to normal.
  • 285 Answers
Ty reattaching the monitor cable to the monitor and PC.
If that does't work, try another cable.
One of these should solve your problem.
Posted on May 19, 2009
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
Color problem
It sounds like the set has become magnetized. It could possibly be from an external speaker magnet or some other magnetic field (ie. a vacuum motor). It could also be a malfunction in the built in demagnetizer circuit. Color picture tubes are very sensitive to magnetism. Because of this there is a built in demagnetizer circuit. If this circuit malfunctions it can cause the same problem. Turn the set off and unplug it for 30 minutes or so. This will allow the circuit to cool off and reset. Turn the set back on and see if it returns to normal. Also, dropping the set or a heavy jar can warp the shadow mask inside the tube causing the same problem. If the unplugging method does not work, have a shop check it for you. Thanks for using fixya.
Mar 02, 2010 | Panasonic Televison & Video
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
Projection tv color issue
Our tv has gone very green and we can't seem to adjust it back to normal. Do you have a solution for that??
Nov 27, 2008 | Televison & Video
I have a 42" Ultravision TV, and suddenly every thing has gone green, and the reds have gone. I've rebooted the cable system a few times, and it's still green. My other TV is fine, so I'm guessing...
don't run it like that suspect shorted crt or video output try adjusting the screen control for the specific color if no change then it is as mentioned put screen control back to the starting spot.
Oct 07, 2008 | Hitachi Televison & Video
Red has gone off from the blue and green
you can use color managemnt option on your t.v to fix this problem. Also some newer tvs now have grid color managment, which lets you play around with it and let you pick what you want or where you might need or not need the color.
Feb 07, 2008 | Philips 46PP9302 46" Rear Projection...
How do I decrease the amount of green in the picture?
Unfortunately this model has a bad CRT. If is 3-4 years old and the greenish picture is in all inputs, for sure the picture tube is gone. If the picture is green only in component input check the connections for the blue and red cables.
Dec 26, 2007 | JVC AV-27230 27" TV
Colors displayed
Go to Menu, Advanced, and set the color adjustments to RGB. That should work.
Dec 03, 2007 | Eiki LC NB2UW Multimedia Projector
Color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Oct 01, 2007 | Televison & Video
Toshiba 42HL196 42 in. LCD HDTV Logo
195 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
