Question about Bravo Sports 1008925 Bravo Sports Cirrus Pogo Stick
Can you adjust the tension - Bravo Sports 1008925 Bravo Sports Cirrus Pogo Stick
How do I set the bobbin tension
How to change the tension on a sewing machine?
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine Search for: How to change the tension on a sewing machine?
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+How+do+I+set+the+bobbin+tension ..try this link
Dec 04, 2016 | Sewing Machines
How to adjust tension on bottom?
Usually, tension adjustments are made to the top. The bobbin tension is adjusted mainly only when using a different weight of thread (either very thin or very thick). Very seldom is the bobbin tension changed.
Understanding Thread Tension Threads
http://ohyoucraftygal.blogspot.com/2013/10/sewing-lesson-10-how-to-fix-tension-on.html
https://www.craftsy.com/blog/2015/03/how-to-adjust-sewing-machine-tension/
Nov 08, 2016 | Sewing Machines
The bobbin thread shows to the front. Does the bobbin or thread tension need adjusted
Generally, tension adjustments are made using the upper thread tension. Most likely the upper tension is set too tight and is pulling the bobbin thread up. Loosen the upper tension and try again. Tension is accurate when the upper thread and bobbin thread meet in the middle of the fabric. Whenever fabric, thread & needle are changed, there may be a need to adjust the upper tension.
HINT: When threading the upper thread, make sure the presser foot is RAISED during threading to make sure the upper tension disks are open and the thread seats properly.
Bobbin tension is only adjusted when the tensions are way out of whack. Only slight turns of the bobbin case tension screw are made in graduated movements and testing occurs after each adjustment.
Jan 20, 2016 | Sewing Machines
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
Model 1507 tension
I'm sorry, but you will have to be more specific. There is a top and bottom tension. The top tension is adjusted using a dial of some kind, visible on your machine. It has numbers on it; generally the lower the number, the tighter the tension. The bobbin tension generally does not need adjusting, although it can be adjusted. Please write again to let me know what it is doing that leads you to believe the tension needs adjusting.
Dec 11, 2013 | Singer 1507
How do I replace the serpentine belt on a 1994 concorde?
Remove the alternator/power steering pump and water pump drive belt to gain access to the air conditioning drive belt.
To remove and install the air conditioning compressor drive belt, first loosen the tensioner pulley lock nut, then turn the adjusting screw to raise or lower the tensioner pulley assembly Accessory Drive - 3.3L Engine or Accessory Drive - 3.5L Engine To adjust the air conditioning drive belt, loosen the tensioner pulley nut and adjust belt tension by tightening adjusting screw. Torque pulley nut to 54 N•m (40 ft. lbs.) after adjustment.
The Poly-V generator/power steering belt has an adjustable tensioner pulley located on the timing belt cover Accessory Drive - 3.5L Engine to maintain proper belt tension. To remove or install this belt, Release tension by loosening the tensioner pulley nut and adjustment bolt Accessory Drive - 3.5L Engine Reverse procedure to install and tighten belt to specified tension.
Jul 10, 2012 | 1994 Chrysler Concorde
I'm trying to change the belts for my 92 tercel but some how cant find the tension pulley. Can anyone please help me. I need to change both belts.
It appears that your car is equipped with multiple v-belts, rather than a serpentine belt so there most likely aren't tensioner pullies. Here is some general info that may help.
Alternator To adjust the tension of the alternator drive belt on older models, loosen the pivot and mounting bolts on the alternator. Using a wooden hammer handle, or a broomstick as a prying device, move the alternator one way or the other until the proper tension is achieved. Do not use a screwdriver or any other metal device such as a pry bar, as a lever. Newer models use a tension adjusting bolt. Loosen the pivot bolt and the locking bolt, then turn the tension adjusting bolt until proper tension is achieved. Tighten the bolts securely, run the engine about minute, stop the engine then recheck the belt tension. Air Conditioning Compressor A/C compressor (always use caution when working near the A/C compressor to avoid damaging the refrigerant lines) belt tension can be adjusted by turning the tension adjusting bolt which is located on the compressor tensioner bracket. Turn the bolt clockwise to tighten the belt and counterclockwise to loosen it. Air Pump To adjust the tension of the air pump drive belt, loosen the adjusting lever bolt and the pivot bolt. Move the pump in or out until the desired tension is reached. NOTE: The tension should be checked between the air pump and the crankshaft pulley on cars without air conditioning. On cars with A/C the tension should be checked between the compressor and the crankshaft pulley. Power Steering Pump Tension on the power steering belt is adjusted by means of an idler pulley (some models may use just a lower adjusting bracket setup, similar to the alternator adjustment service procedure). Loosen the lock bolt and turn the adjusting bolt on the idler pulley until the desired tension is felt, then tighten the lock bolt.
Feb 12, 2011 | 1992 Toyota Tercel
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
1998 dodge neon airconditioning belt adjustment?
This procedure involves correcting the tension on the power steering accessory and A/C compressor drive belt.
1. Loosen the power steering pump locking bolts A and B and pivot bolt C(Illustration 1 and 2 ) to allow adjustment of belt tension.
2. Using a 1/2" breaker bar, adjust belt tension by applying torque to the square hole "D" on the power steering pivot bracket. Adjust the tension as follows:
Belt tension with no belt replacement: A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 100 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
Belt tension with belt replacement:
A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 135 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to 27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
C. Start the engine and allow the vehicle to idle for 15 minutes to allow the belt to seat.
D. Repeat the belt tensioning procedure, set belt tension to 135 lb.
click here for picture 1
click here for picture 2
Jun 13, 2008 | 1998 Dodge Neon
Bravo Sports 1008925 Bravo Sports Cirrus Pogo Stick Logo
607 people viewed this question
Top Bravo Sports 1008925 Sport & Outdoor - Others Experts
Are you a Bravo Sports 1008925 Sport and Outdoor - Other Expert? Answer questions, earn points and help others
