Question about Lexmark X5650 All-in-One InkJet Printer
Application Download my printer X5650 will not scan. says downloading application list and then cannot retrieve application list.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 544 Answers
If you turn off the printer and then back on. This may clean the problem.
Posted on Dec 30, 2013
SOURCE: scanning with my printer
Funny you just posted this yesterday and I had the same problem at the same time. (driver timb bomb?) Any way, the solution that worked for me was to: 1. Unplug the printer. 2. Uninstall the drivers. 3. Reboot the machine. 4. Go to the lexmark site and download the drivers. 5. Install the new drivers. Everything is working great now. It is nice to have simple solutions once in a while. :)
Posted on Aug 21, 2007
  • 4 Answers
SOURCE: cannot retrieve application list on scanner
try boosting the power couplings followed by initiating the inter-active recipter valve. Once you see the deflanger code type in +.ak234//pp.HO.
This open up the transducer allowing the flow of typherical codes that was being block preventing you scanner from downloading the application list.
If this doesn't work, write your Congressman.
Posted on Nov 08, 2008
SOURCE: Cannot scan anything on my lexmark 4550
There is a patch that you can download and run to resolve this issue.
Step 1:
Download the following patch: http://swdownloads.lexmark.com/Patches/3500-4500/3500-4500.exe
  1. To start the process, double-click on the downloaded file and follow the on-screen instructions to continue.
  2. Reboot the PC.
  3. Unplug the power adapter from the back of the printer.
  4. Plug it back in after 30 seconds.
  5. Try to scan again.
    If the problem still exists, follow Step 2 below.
Step 2:
Download the following patch: http://swdownloads.lexmark.com/Patches/3500-4500/3500-4500wifiethernetpatch.exe
  1. Double-click on the downloaded file and follow the on-screen instructions to continue.
  2. Reboot the PC.
If the problem is still the same
1.Get the printer ip address of the printer (ex: 192.168.1.10)
-press settings on the printer panel.. go to network setup.. View TCP / IP, open a browser (IE or mozilla) and type in the printer ip address
-you will see the printer page and then go to configuration.. choose scan to network host
-delete all the computer name listed
2. Go to start, all program.. choose Lexmark 3500-4500 series and choose Lexmark Solution Center
-go to Advanced, click on networking and then click on Change PC name or PIN
--rename the PC name and then click on Ok
3. Turn off the printer, unplug it for 10 secs
4. Try to scan, it should work
if it's still the same you need to uninstall the printer driver and download the updated driver in Lexmark.com
-reinstall it using the downloaded driver
GOODLUCK!!!
Posted on Sep 25, 2009
SOURCE: My new Lexmark X5650 doesn't scan to computer.
I had my phone turn off,but can still use my computer on line,and now my three in one printer is saying downloading application and then it say can not retrive.
Posted on Jan 07, 2010
SOURCE: Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Posted on Jul 07, 2010
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5650 cannot retrieve application list
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 16, 2012 | Lexmark X5650 All-in-One InkJet Printer
Lexmark x5650 all in one won't download application list
Try to download and install the Lexmark X5650 printer driver for Windows 7 from the Lexmark website. First, disconnect your printer from your computer. Then, check if your computer system is running on 32-bit or 64-bit. On your computer, go to Start > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below for the corresponding driver for your operating system:- Lexmark X5650 driver for Windows 7 32-bit- Lexmark X5650 driver for Windows 7 64-bit
Simply follow the instructions on your computer screen to complete the installation. Then try to scan again to verify that the problem is fixed.
Nov 16, 2011 | Lexmark X7350 All-In-One InkJet Printer
"Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printer will not scan to computer
This is my problem also. I get a message "waiting for application list to download." What's the application list? , and then, it will either turn off the indicator or just hang on "scan to computer". I have downloaded the Lexmark drivers but that doesn't help. Please post a solution, thank you.
Feb 04, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
My new Lexmark X5650 doesn't scan to computer. Each time I try it shows the message "Downloading Application List." The it shows "Application Acrobat Reader." After a while it goes to sleep, but doesn't...
Dec 22, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 cant scan
TRY TO REINSTALL THE SOFTWARE AND A DRIVER FOR THAT MODEL DRIVER
Aug 06, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Scanning with my printer
No its seem to be some software clashed problem! Try to remove your old software and then try to clean registry and then install again then it should work!
Dec 08, 2007 | Computers & Internet
Lexmark X5650 All-in-One InkJet Printer Logo
97 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
