Question about DCS Heating & Cooling
Need circular heat deflector, 34" in diameter for DCS heater, model #PHSS-DW-GN-L
Need to replace the 34" circular heat deflector on our DCS Professional Patio Heater
4 Suggested Answers
  • 5 Answers
SOURCE: I´ve lost the switch for my dcs patio heater.
can you get me the model # and all info please?
and i will check with my ocntacts to see if we can get you one
Posted on Mar 31, 2008
  • 111 Answers
SOURCE: flame out on a DCS Patio Heater
thermo-coupler (cheapest to fix) or valve
Posted on Jan 31, 2010
  • 70 Answers
SOURCE: I need to replace the
A thermo couple is universal can get at lowes/Home depto
Posted on Aug 28, 2010
I have a 2011 Chevy Cruze with no heat. Replaced water pump and thermostat. Flushed heater core. Still no heat. What should I do next
you need to check your blend door motor. Also, did you make sure to bleed all the air out of your system?
Feb 16, 2017 | Cars & Trucks
Is it more economical to connect both taps hot and cold or connect cold only and have the machine heat the water
JMHO, but guessing it's probably better to connect hot water to the DW. It could be taxing on the DW to heat cold water every time. At least with hot water available, the DW wouldn't have to work so hard and maybe your DW will last longer--or at least the heating element probably would. Can't imagine the cost of using pre-heated water (from a hot water heater) would be extravagant as a DW probably doesn't use that much water each time.
Mar 19, 2016 | Washing Machines
Error code He
he error code is a heating error. check the wire connections to the heater, if no problem then you need to check for continuity to the heating element. You'll need a meter to do this. The heater assembly may need replacing. I think they run around $60. We had a Samsung DW for 4 years...finally gave up & replaced with a GE which has been working well.
Jul 11, 2014 | Samsung DMR78AHS Builtin Dishwasher
Skilsaw 5380 Roller Pin Removal
To remove a rolled pin you need to use a punch tool like a small chisel with a constant diameter and a flat tip. They sell these in chisel sets at Sears and other places. Or you might be able to use a bolt of the right diameter and tap it with a hammer. Don't use a nail though, too soft, it will just jam in there. Good luck.
Aug 28, 2012 | Skilsaw 5380 Circular Saws
My GE electric dryer has been making a loud rattling and squeaking noise. Now it is taking a lot longer to dry the clothes. Model # DBSR453EB2WN
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DWSR483EB0CC/0432/0151200/G0205230/00004?blt=06&prst=&shdMod=
As you can see in the diagram the heating element is on the back side of the deflector plate. I would WAG that something got past the deflector and is rattling around between the heater assembly and deflector plate. OR something has come loose and is doing the same thing in that area of the machine. When you have it opened up you should also check the bearing and replace if there is any wooble in it and if not lubricate thoroughly.
Jun 19, 2011 | GE DWSR483EBWW Electric Dryer
I have a 2001 dodge ram. NO HEAT but the fan and ac works
If the air deflector is moving correctly, Make sure your thermostat is not hanging open and that your coolant level is up to standards. While the engine is at running temp. check the two hoses that go through the firewall to the heater core. If they are both hot than one of the servos, vacuum or motorized may not be moving the deflector doors correctly. Try to hear any movement when you switch back and forth between defrost and floor heat.I doubt you need to replace the heater because of the age of your vehicle. Try to watch for any movement under the dash while you move the control. Good luck, Dana
Sep 04, 2009 | 2001 Dodge Ram 1500 Truck 2WD
All all water inlet valves created equal :)
The short answer is no, all dishwasher valves are not the same. Newer dishwashers use much less water than older ones, and the valves are often ones which allow a lower flow rate (just like newer shower heads with low flow rates to conserve water) so that the timed fill cycle lets in a smaller amount of water. I do not have parts info for DCS, but this is what I would try: Units old enough to have discontinued parts probably did use basically the same water valves back then. Try a GE valve # WD15X93. The mounting may have to be modified, but you could even let the valve hang without mounting it to the dishwasher. (won't hurt a thing) Please don't bother rating this, as anything other than a FixYa will lower my score. Thanks.
Dec 11, 2008 | DCS DW-24-SS Built-in Dishwasher
Mar 30, 2008 | DCS PHFS Phoenix III Outdoor Patio Heater
Replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Dec 08, 2007 | Kenmore 64892 Electric Dryer
Heating & Cooling Logo
23 people viewed this question
Top DCS Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a DCS Heating and Cooling Expert? Answer questions, earn points and help others
