Question about Emerson MWG9111SL Microwave Oven With Grill
I can't turn the voice feature back on my emerson MWG9111SL.
I can't turn the voice feature back on. My emerson microwave has an optional voice feature that talks when you hit certain keys. I turned it off when I first got the microwave. Now I can't remember how top turn it back on. Please help. It's not in the owners manual. Instructions to turn the voice on and off were on a separate card that was with the packaging.
WGCowen
  • 5 Answers
SOURCE: Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Posted on Jul 26, 2009
SOURCE: I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
Posted on Nov 25, 2009
  • 234 Answers
SOURCE: my emerson mwg9111sl microwave runs but does not
assuming the micro responds to whatever setting you set on the controls, that is: time, temp, & on/off , then the problem most likely is in the magnatron energy portion. Of this portion, the biggest problems are the hi-volt diode and hi-volt capacitor, or the connections to them (sometimes arc and burn to the point of failed contact). CAUTION: there is 2000volt stored energy in this circuit and it will shock you very much if you do not de-energize it; simply unplugging the unit will not deenergize this portion of the circuit. You must short the terminals of the capacitor with a metal object that has an insulated handle. If you get a reasonable spark from this shorting, then the capacitor is probably ok, and the diode (black rectangle attached to one terminal of the capacitor) is the culpret. However, if the diode is bad, the capacitor may not charge up and you think it is bad (when in fat it is not). You need a capacitor tester or you need to remove the capacitor and have it tested, so also the diode tested. If these test ok, then you either need the power transformer or the magnatron. The tranformer and magnatron are expensive to by as lone parts; better to find a discarded micro and salvage these parts (they are very interchangeable to a greater degree).
Or, go to a appliance repair place after you have checked out your unit and tell them that you need these parts tested . I'm sure they will have some salvage parts to offer you. Goodluck, Macgivor
Posted on Jan 02, 2010
hmerchant110
  • 7191 Answers
SOURCE: How can I get a free owners manual for my Emerson
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jun 22, 2010
Testimonial: "God bless you. You've saved my sanity and found the manual for me!!"
MicrowaveSvc
  • 9047 Answers
SOURCE: Throws breaker everytime I plug it in Emerson
That would be a bad monitor interlock (middle door switch) or its mount is bad.
See this help file on door switches.
Posted on Jul 10, 2011
How do I set the clock on Emerson microwave model mwg9111sl
Hello!
Here is the link to the manual for Emerson MWG9111SL - setting the clock.
I hope it will help!
Microwave Cooking Emerson MWG9111SL 8 23
Jun 19, 2017 | Emerson Microwave Ovens
Shut itself off and wont turn back on (totally dead) on a good electrical outlet
maybe the fuse blown inside the oven if you are lucky... try to look at it but there's a reason why the fuse blown usually a short circuit in one of the parts...
Dec 09, 2013 | Emerson MWG9111SL Microwave Oven With...
Shut itself off during cooking and wont turn back on
I had a similar problem with a different make of microwave oven with grill and, on taking the cover off, found that a normally closed thermostatic switch (little round thing, with tab connectors - one of three, in my m'wave) had burnt out. I suspect that this switch had a manufacturing fault which took some time to show up. On a certain website with a 'buy it now' option I was able to buy a pack of three of these parts for very little money, from China. The temperature rating of these switches is marked on the casing.
I need an owner's manual for an Emerson Microwave Grill - Model #MWG9111SL. Mfg. July/08. Do you know where I can find one?
It's here:
http://www.emersonradio.com/owners/MWO%20manual/Manual%20of%20MWG9111SL/MWG9111SL.pdf
Sep 07, 2010 | Microwave Ovens
Emerson MWG9111SL microwave reset switch
my microwave stoped woring and i dont know where the reset button is can someone help
May 19, 2010 | Microwave Ovens
I have am emerson mw mwg9111sl how do i set the time on it?
The owner's manual is here.
Jan 29, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Light bulb replacement
the light bulb is usually in cavity behind the control board.to access that first remove the outer cover of the unit by removing all screw at the back.after removing the cover u will have access to yhe cavity behind the cntrl board and the light bulb.....good luck.
Aug 19, 2009 | Emerson MW8168B Microwave Oven
Jun 01, 2009 | Emerson MW8168B Microwave Oven
Emerson mwg9111sl microwave oven won't turn off unless unplugged
I would suspect a bad door switch or mount or a problem on the control panel.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020.
Get help locating a local authorized servicer at 1-800-695-0098.
Nov 21, 2008 | Microwave Ovens
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
Emerson MWG9111SL Microwave Oven With Grill Logo
22 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
