Question about Dirt Devil Vacuums
I pugged the dirtdevil 087800 to do some cleaning and it started smelling like there a burn wire
What is the problem, how or where can I locate the burnt part, does it have a fuse, where is it located? It is not belt problem, I have checked it and it is ok.
  • Dirt Devil Master
  • 1,460 Answers
If it's been over six months since belt replaced start there first. Belts may look ok and brush might spin but when sweeping the belt will slip on the brush roll.
Posted on Jan 29, 2014
debbily
  • 101 Answers
SOURCE: belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Posted on Oct 16, 2007
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
  • 548 Answers
SOURCE: burning smell when vacuuming, not belt
Try turning the vacuum on and hold the base up so you can see if the roller is turning. Odds are it is not and what you smell is the belt burning (not literally). If the roller is not turning, look for anything that is binding it - after you have unplugged the power cord. Probably the roller head is not fully aligned with the retention lugs that hold it in place or the belt is not properly placed on the roller itself, or if it is a used model, hair and twine can get tangled in the roller and cause it to stop turning.
Posted on Dec 26, 2008
  • 294 Answers
SOURCE: burned smell
If the motor slowed down this would indicate a bad motor. not cost effective on this model to replace unless under warranty. it is not uncommon these days to see a motor go bad every now and then.
What are the first 4 digits of your serial number? this would be the month and year of mfr. even without a receipt, a warranty service shop should be able to assist you.
Posted on Jan 19, 2009
  • 294 Answers
SOURCE: I put a new belt on my oreck xl and it is burning through why?
The problem you are having is that the brush roller is not spinning freely when the belt is not on. if the end caps of the roller can be removed, clean the dirt & carpet fiber out and test. if it can not you just may need to replace the roller
Posted on Feb 02, 2009
How to fix dirt ***** easy steamer deep cleaner, it is leaking water?
Hi there! Check the clean water tank valve to see if that is where the leak is coming from. If so, your clean water tank will need to be replaced. If the leak is coming from somewhere else we recommend taking the cleaner in to a Dirt Devil authorized service center for repair. I have included a link where you may locate the nearest service center to you. Hope this is helpful. If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Service Center Locator
Aug 22, 2014 | Dirt Devil Featherlite Easy Steamer Extr...
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
Nov 03, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
My dc24 has started making a loud noise which seems to be coming from the ball. I switched its off when it started to smell of a slight burning or warm smell. Vacuum is only 2.5 years old, filters are...
Sounds as if there is something stuck in the vacuum causing the beater bar to stop turning while the belt continues to turn giving off the burning smell.
Oct 27, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Kenmore quick clean burning smell
is the belt tight enough? does the brushroll turn easy?
Aug 21, 2009 | Kenmore Quick Clean 30012 Vacuum
Dirt devil en vision
download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Jun 15, 2008 | Dirt Devil CE5500 Floor Keeper Upright...
Vacuums Logo
60 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
