Question about Bushnell Pinseeker 1500 Rangefinder
Battery cover replace battery cover
Instructions to replace battery cover for canon powershot a2000 is
1) Purchase replacement battery cover.
2) Remove original battery cover
3) Attach new battery cover.
Jun 23, 2017 | Canon Cameras
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
How do you replace batteries of a Sentry S0607?
How to install electronic fireproof sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
New advanced electronic lock safe battery replacement instructions
May 05, 2010 | Sentry Fireproof Safe
Lost battaries compartment cover
I lost my radio shack sangean 909 battery cover too! where do I get a replacement?
Jan 26, 2010 | Sangean ATS 909 AM/FM/SW Radio
How do I replace a SIM card in a Nokia 2115i?
firstly turn off your phone then open the battery back cover which easy just slide then take out the battery and you will see the sim card holder take out old sim card and put new sim card then put battery back and put back cover.
Dec 30, 2009 | Nokia 2115i
Replacing the cover for the batteries. I have the
There is no instructions.Remove the cover nut's and keep those carefully.u can remove battery cover after that.
Nov 01, 2009 | Canon PowerShot A40 Digital Camera
Battery Cover Replacement Part for Kodak CX7330
I did the same thing. Is the little medal piece still on the inside of the battery cover. If not you will have to replace the entire door and you should be all set.
May 22, 2008 | Kodak EasyShare CX7330 Digital Camera
Bushnell Pinseeker 1500 Rangefinder Logo
63 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
