Question about Danby DDR4009EE Dehumidifier
Where can i find a manual for model ddr4009ee
Manual for super clima model dg50
I HAVE A SUPER CLIMA MODEL DG50 LISTED HOMOLCUE TYF9 DEHUMIDIFIER AND NEED AN OPERATING MANUAL
Jan 31, 2013 | Dehumidifiers
Frigidaire dehumidifier model no -FAD504TDD,Manual
Hello dinesh878 - I found the manual on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. I will recommend taking off the last letter of the model number so you can pull up the information.
http://b2b.frigidaire.com/support/manuals.asp?NewSearch=New+Search
Nov 14, 2012 | Frigidaire Dehumidifiers
Were is the filter located and how is it removed for cleaning
Access to the air intake filter can be gained by pulling out the filter holder, which is located on the right side of the unit, on the same level as the louvers on the front.
Since you model has been discontinued, I am providing a link to you Owners Manual, that you can download and print for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR2509%2C_3009%2C_4009EE_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 09, 2011 | Danby DDR4009EE Dehumidifier
P1 constantly goes on throughout the day. I do not know if I have the setting right or if the drain hose is connected properly.
First, the drain hose should not be longer than 5 feet and should be draining downward, with no kings or bends in the hose, The dehumidifier does not have a pump. It relies on gravity to drain the water.
As far as it running all day is concerned, some dehumidifiers have a "Constant" or "Continual" setting. Which means it runs constantly. Either while dehumidifying or defrosting. In addition, most Danby dehumidifier models are designed to have the fan run even when the compressor is not running. This is in order to circulate the air in the room and make the unit work more efficiently. This is a standard feature and cannot be programmed to stop.
Hope this answered you questions.
Apr 24, 2011 | Danby DDR4009EE Dehumidifier
What does p1 on the screen mean
Clean the filter and reset it.Still the problem persists, check the speed of F.M.
Dec 02, 2010 | Danby DDR4009EE Dehumidifier
All the lights are on and the dehumidifier isn't working
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 06, 2010 | Danby DDR4009EE Dehumidifier
Operating manual for M7DH65B2A
match the model to a sears model - their manuals are on line at searsdirect.com
Jan 05, 2010 | Maytag M7DH65B2A Dehumidifier
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
Danby DDR4009EE Dehumidifier Logo
32 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
