Question about Stoves 850DODLM Gas Kitchen Range
I have no instructions for my stoves envoy cooker, need to know how to set 3 button timer and grill wont ignite, help!
  • Anonymous Mar 23, 2014
    no ignition
    Problem Solver:
  • 7 Answers
You can ring stoves on 08712222502 they will usually email over a manual for free you just need your model and serial number of your oven.
This can be found usually just behind the door to the grill.
hope this helps :)
Posted on Jun 01, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Manual for tricity contessa cooker, double oven and grill with slow cooker button. Just brought this reconditioned cooker, but it hasnt got a manual and I need one. I can't get the oven to turn on, it...
i have a vey old tricity contesssa cooker(which i love!)
The rings are heating but the oven and grill have stopped working,any suggestions on how to fix please??
Oct 08, 2011 | Ovens
I cleaned the cooker the other day as I wiped past the timer buttons I must have tripped the timer, I now have the letter 'A' flashing I can not turn the oven on. How do I put the oven back to mannual...
Sorry to read about your problem, I hope this helps you out.
Try and rest your circuit breakers.keep off for 5 secs
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Stoves 1100DFSID Kitchen Range
I have a green envoy gas cooker. mod no 050564096 serial no 001208. it has 5 buttons for the clock and timer and i dont know how to set it after we had a power cut. the rings work and small oven and...
I have a manual for the 850 DO and it says the following
Setting the "time of day"
1. Switch on electricity supply to the appliance
The display will flash
2. Press and release the time of day button
3. Set the time of day with the plus and minus buttons
4. The time will be set 7 seconds after the last plus or minus operation.
Hope this helps!
Nov 06, 2010 | Stoves 850DODLM Gas Kitchen Range
The time on my Stoves Richmond cooker clock is wrong and I need to put it right so I can set the timer. I can't remember how to reset either the clock or the timer. Can ou help?
I think it's the same model as mine - if so... press the + and - buttons simultaneously (for a very brief time), until the middle dot 'flashes'. Release the buttons then adjust the time using the + and - buttons. Job done!
Oct 26, 2010 | Stoves Richmond RM1000DF Dual Fuel...
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Stoves 850DODLM Gas Kitchen Range Logo
1,585 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
