Question about Casio G-zone Commando
Casio comando clock widget - Casio G-zone Commando
I want to remove widget (clock) from the home screen so the picture is not obscured.
just touch the widget for few seconds...then on upper right or left side u will see the remove written on the screen.....now move that widget to that place and u will see no more widget over there.
Aug 19, 2015 | Cell Phones
What is a widget
In computing, a web widget is a software widget for the web. It's a small application with limited functionality that can be installed and executed within a web page by an end user. A widget has the role of a transient or auxiliary application, meaning that it just occupies a portion of a webpage and does something useful with information fetched from other websites and displayed in place. Other terms used to describe web widgets include: portlet, web part, gadget, badge, module, snippet and flake. Widgets are typically created in DHTML or Adobe Flash.
Widgets often take the form of on-screen device such as clocks, event countdowns, auction-tickers, stock market tickers, flight arrival information, daily weather etc..
Nov 30, 2013 | Cell Phones
Htc one clock
The clock settings and choices are within the "widgets". Rest a finger lightly on the screen for 1 to 2 seconds and the widget mode will become visible showing clock and other widgets.
Nov 18, 2013 | Computers & Internet
Which android weather app is the absolute best?
I just read an article on lifehacker that said that the best android weather app is weatherbug. The basic version is free, but the premium version will cost you.
http://lifehacker.com/5982791/the-best-weather-app-for-android
Feb 13, 2013 | Android Apps
Lost my original clock how do i get it back
You can restore the clock using the same procedure as putting any widget on your phone.
Go to the screen where you want the clock and then do a "long press" on an empty portion of the screen. Basically hold your finger on the screen for 3-5 seconds until the widget menu appears.
- Tap Widgets (it may be under a separate menu like "Sense Widgets"
- Scroll to the widget that you want and tap to select it. If there are any customization options, they will come up now. Choose the options you want and then select Done. Your widget will now be on your screen.
You can move your widget by doing another long press on the widget and dragging it where you want it and then releasing.
Mar 06, 2011 | HTC Desire HD Cell Phone
I accidentally removed the clock/weather widget from my home screen trying to pull down my notifications bar, and now I can't find it! How do I get it back?
It's actually a pretty simple way to add widgets back to your home screen.
Long press a blank area of your home screen. A dialog box to Add to Home will appear. Select Widget, and then select Clock [HTC]. You will be able to select from 12 different HTC Clock widgets. Select the one you like, and then press the Select button. It will appear on your home screen as long as there is enough room for it. You can move the widget around by long pressing on the widget and sliding your finger to the desired location on the screen.
Good luck.
Feb 01, 2011 | HTC Hero Smartphone
Alarm icon is displayed in the center of the screen no matter what I do. All alarms are turned off. I've rebooted the phone several times including removing the battery. What else can I do?
I've had this same weird problem today but I think that I may have solved it.
1. Go to "Menu"
2. Go to "Settings"
3. Go to "Display and Light"
4. Go to "Widget". Among your widgets is one called "Analog Clock". Un-check it and Save the widget screen.
5. Go out of the Menu to the top screen (that has "dial", "contacts" and "menu" at the bottom.) Hopefully, the alarm icon is gone. However, the "Analog Clock" that displays the time in the widgets (opened by the small arrow on the left side of the screen) is also gone. Simply go back through steps 1-4 to get to the "Widgets" screen and check the "Analog Clock". Your Analog Clock should display and the Alarm icon should still be gone.
I know that this solution doesn't seem to make much sense because what does an Analog Clock have to do with an Alarm icon? It just seems to be a software glitch of Samsung.
Try it out and see if it works.
Aug 14, 2010 | Samsung Solstice SGHa887
I lost my external clock on my env touch...i tried adding the widget but it didn't work...what now?
From your shortcut menu try pressing the clock widget icon, hold and drag to the background. Should work.
Feb 08, 2010 | LG enV Touch VX11000 Cell Phone
Casio G-zone Commando Logo
13 people viewed this question
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
